Version management
Every time a recipe is saved, a version of the recipe is saved. Previous versions of a recipe can be restored at any time. Recipe versions can be viewed in the Versions tab and are denoted by their version number.
In the version history view, each version is attributed to the user who made the change (relevant for multi-user team accounts), with a timestamp when the version was saved, as well as the change type associated with that version.
Recipe versions as viewed from the Versions tab
The are 2 types of changes:
- Logic change
These changes driven by user actively changing the recipe. e.g. adding or removing steps and changing field mappings, will create a new version of the recipe when the recipe is saved.
- Schema change
These changes are driven by Workato when it notices that the underlying schema of objects in the recipe has changed. e.g. when using a Salesforce custom object has a new field added.
Such schema refreshes will auto create a new version of the recipe.
Restoring versions
To restore previous versions of the recipe, switch to the Versions tab to view all available versions. Recipe versions can be first previewed before being restored.
Previewing and restoring a previous version of the recipe
Restored versions will be created as a new version. In the following case, the recipe had 3 versions initially. When version 2 of the recipe was restored, the restored version was created as Version 4.
Restoring version 2 of the recipe creates that copy as version 4
