Search for a pipeline
You can search for a pipeline from the App homepage.
From the app homepage, select Search Pipeline.
Configure the Search Pipeline interface.
- ELT Control ID
- Optional. This is the pipeline's automatically generated UUID.
- Sample value:
9c3b7d37-f960-4ef0-ad8b-045f8c7803bd
- Created by
- Search for the creator using an email address.
- Sample value:
- [email protected]
- Search from
- Optional. Start date for pipeline creation.
- Sample value:
2021-01-04
- Status
- Filter pipelines by their status. Extract pipelines have a unique status.
- Can be one of:
- Active
- Inactive
- Pending
- Error
- In progress
- Extract
- Source
- Optional. Filter pipelines by their source system. Search results depend on sources defined using the Create pipeline interface.
- Sample value:
- Salesforce
Click Submit.
The ELT Pipeline bot returns the following fields for each pipeline:
- Pipeline name
- ELT control ID
- Created by
- Load type
- Status
- Last successful job URL
- Pipeline created date
- Next run date
RETRY BUTTON
The Search pipeline output truncates to the top five (5) search results. Click the Retry button to search again with different criteria.
Pin a pipeline
You can only pin pipelines after searching for them. To pin a pipeline to your home page, select the Follow button.
You can edit and activate or deactivate a pinned pipeline using the view interface.
