# JSON tools by Workato
The JSON tools by Workato connector enables you to extract values from raw JSON content. This connector can process structured data stored in files or passed through other sources when Workato doesn't automatically expose the content as datapills.
# How JSON tools by Workato works
JSON tools by Workato provides the Parse JSON document action, which parses a JSON document using a sample structure to define the output schema. The result is an array or object of usable datapills.
# Setup
JSON tools by Workato is a built-in connector. It doesn't require authentication or connection setup.
Last updated: 4/1/2025, 2:07:47 AM
