# YAML tools by Workato
The YAML tools by Workato connector enables you to extract values from raw YAML content. Use this connector to parse structured data stored in files or embedded in documents when the YAML structure isn't automatically exposed as datapills.
# How YAML tools by Workato works
YAML tools by Workato provides the Parse YAML document action. This action parses a YAML string or file using a sample structure to define the output schema. It returns structured datapills that match the YAML content.
# Setup
YAML tools by Workato is a built-in connector. It doesn't require authentication or connection setup.
