Configuration Fields
Occasionally, input/output fields depend on user input. For example, when input fields for an action depend on a user's input in the same action. Here, we introduce config_fields. It is an optional key available in both actions and triggers. It is a special type of input field that can be used to generate other dependent input/output fields. We see this in the merge_document action in Webmerge.
Sample code snippet
action: {
  merge_document: {
    config_fields: [
      # this field shows up first in recipe as a picklist of documents to use
        label: "Document",
        control_type: :select,
        pick_list: "documents",
        optional: false
    input_fields: lambda do |object_definition|
      object_definition["document"]
    end,
    execute: lambda do |_connection, input|
      d = input["document_id"].split("|")
      post(d.last.to_s, input)
    end,
    output_fields: lambda do |_object_definition|
    end
Here, the fields are different for each document, hence a user first chooses a document (from a pick list of documents available in the instance) which is then used to generate the remaining fields. This part is done by specifying that the "document" object definition is dependent on the value of "document_id" within config_field. Notice that the fields block accepts a second argument config_fields. This argument refers to the field(s) you define in config_fields in each action/trigger.
object_definition: {
  document: {
    fields: lambda do |_connection, config_fields|
      return [] if config_fields.blank?
      get("https://www.webmerge.me/api/documents/#{config_fields["document_id"]}/fields").
        map { |field| field.slice("name") }
    end
While the config_fields is empty, document objects will have no fields (empty array of fields). As soon as config_fields is given a value, a request is made to retrieve the fields present in this document. From a recipe user perspective, the action will appear initially as a single input with a list of documents. After selecting a document, the corresponding set of fields will be generated, to be used in the recipe.
config_fields schema screenshot Configuration fields in action
results matching ""
    No results matching ""
