# Recipes for the ELT Pipeline for Snowflake accelerator
This accelerator contains a set of recipes to implement the ELT Pipeline for Snowflake bot in Slack and a collection of recipes to implement the bot in Microsoft Teams. The recipes relevant to you depend on which package you install.
- Recipes for Slack are located in ELT_Pipeline_for_Slack.zip
- Recipes for Microsoft Teams are located in ELT_Pipeline_for_MS_Teams.zip.
# Recipes for Slack
The recipes in this version of the accelerator are organized in the following folders:
# 04 Functions
- ELT | FUNC-005 | Error Handling [Slack]
- ELT | FUNC-004 | Get ELT Control Table Results [Slack]
- ELT | FUNC-003 | Notify ELT User [Slack]
- ELT | FUNC-002 | Pre-Processing before MERGE [Slack]
- ELT | FUNC-001 | Pre-Processing of Schema [Slack]
# 03 Data Load
- ELT | DTL-003 | Files | Extract and Load [Slack]
- ELT | DTL-002b | PostgreSQL | Extract and Load [Slack]
- ELT | DTL-002a | SQL Server | Extract and Load [Slack]
- ELT | DTL-001 | Salesforce | Extract and Load [Slack]
# 02 Controller
- ELT | REC-001 | Pipeline Scheduler [Slack]
- ELT | CAL-001 | Job Dispatcher [Slack]
# 01 UI
- ELT | SUI-002 | Manage Pipeline
- ELT | SUI-001 | App Home Page
# Recipes for Microsoft Teams
# 04 Functions
- ELT | FUNC-005 | Error Handling [MicrosoftTeams]
- ELT | FUNC-004 | Get ELT Control Table Results [MicrosoftTeams]
- ELT | FUNC-003 | Notify ELT User [MicrosoftTeams]
- ELT | FUNC-002 | Pre-Processing before MERGE [MicrosoftTeams]
- ELT | FUNC-001 | Pre-Processing of Schema [MicrosoftTeams]
# 03 Data Load
- ELT | DTL-003 | Files | Extract and Load [MicrosoftTeams]
- ELT | DTL-002b | PostgreSQL | Extract and Load [MicrosoftTeams]
- ELT | DTL-002a | SQL Server | Extract and Load [MicrosoftTeams]
- ELT | DTL-001 | Salesforce | Extract and Load [MicrosoftTeams]
# 02 Controller
- ELT | REC-001 | Pipeline Scheduler [MicrosoftTeams]
- ELT | CAL-001 | Job Dispatcher [MicrosoftTeams]
# 01 UI
- ELT | SUI-002 | Manage Pipeline [MicrosoftTeams]
- ELT | SUI-001 | Microsoft Teams App Home Page
Start
