# Start
Before you begin, ensure you have completed the following tasks:
- Install the asset package
- Connect your applications
- Set up your lookup tables
- Set up your OPA and OPG
- Set up your custom OAuth profile
# Add the ELT Bot to the notification channel
You must add the ELT Pipeline Workbot you created in Setting up a Custom OAuth Profile for Workbot to the Slack notification channel you configured in the account properties. To add the ELT Pipeline Workbot to the channel, mention the bot in the channel with @bot-name.
# Start recipes
You must start the recipes in this accelerator in a specific order. This order depends on the recipes' parent folder. Start all recipes in each folder before proceeding to the next folder. The folder order is as follows:
- 04 Functions
- 03 Data Load
- 01 UI
- 02 Controller
Last updated: 10/14/2025, 4:38:57 PM
