url: >-
  https://docs.workato.com/en/agentic/agent-studio/chat-interface/headless-api.md
description: Enable your application to talk to your genie directly over a REST API.
# Headless API {: #headless-api :}
The [custom chat interface](/en/agentic/agent-studio/chat-interface/chat-interface#configure-a-custom-chat-interface) lets you connect your genie to any application you build and control. Your application talks to your genie directly over a REST API, called a Headless API, instead of routing users through Slack, Microsoft Teams, or Workato GO.
::: info HEADLESS API ENDPOINTS REQUIRE A CUSTOM CHAT INTERFACE
Headless API endpoints are only compatible with the [custom chat interface](/en/agentic/agent-studio/chat-interface/chat-interface#configure-a-custom-chat-interface) option.
The custom chat interface includes API endpoints to manage conversations and send and receive genie messages. This API is separate from the [Agent Studio Developer API](/en/workato-api/agent-studio#agent-studio), which lets you create, configure, and maintain genies.
::: tip FEATURE AVAILABILITY
Headless API is available to select users. Contact your Customer Success Representative to confirm if it's available in your workspace.
## Headless API prerequisites {: #headless-api-prerequisites :}
Confirm you have the following requirements to use Headless API:
* You have a genie in Agent Studio.
* You've set up the genie's [custom chat interface](/en/agentic/agent-studio/chat-interface/chat-interface#configure-a-custom-chat-interface) from the Agent Studio UI, including creating and attaching a genie client with either API key or OAuth 2.0 (PKCE) credentials. Refer to [Genie clients](/en/workato-api/agent-studio#genie-clients) in the Developer API if you provision the client programmatically instead of through the UI.
* Headless API is enabled for your workspace. Headless API is in private beta: if the **custom chat interface** option doesn't appear in your genie's chat interface settings, contact your Customer Success Manager to request access.
* Your builder role has the **Custom chat interface** privilege under **Genie building**. Refer to [collaborator privileges](/en/privileges.md#custom-chat-interface) for more information on configuring builder roles.
## Headless API base URLs {: #headless-api-base-urls :}
Headless API is available in all data centers where Agentic is supported. The base URLs follow the same per-data-center scheme as the app host. For example:
| Data center | Dev API base URL | Headless API base URL |
| US | `https://www.workato.com` | `https://genie-api.workato.com` |
Refer to the [data center overview](/en/datacenter/datacenter-overview) for more information.
## Authentication {: #authentication :}
Headless API supports the following access methods:
**API key:**
```http
Authorization: Bearer <api_key>
X-IDP-User-Id: <idp_user_id>
**OAuth 2.0 (PKCE):**
```http
Authorization: Bearer <access_token>
### Authorization methods comparison {: #authorization-methods-comparison :}
Refer to the following authorization method comparison and use case recommendation tables to determine which authorization method to use:
|Comparison point | API key (token-based) | OAuth 2.0 (PKCE) |
| **How it works** | The builder's backend holds a static API key and asserts user identity through the `X-IDP-User-Id` header. | End users authenticate directly through Workato Identity and delegate to the customer's IdP through SAML SSO. |
| **End user visibility** | Workato is invisible to end users. | End users see an IdP login step. |
| **Required headers** | `Authorization: Bearer <api_key>` and `X-IDP-User-Id: <idp_user_id>` | `Authorization: Bearer <access_token>` |
| **Client credentials** | The API key is static and is shown only once. | `client_id` only — PKCE replaces the client secret. |
| **User identity managed by** | The builder maps user IDs to Workato IdP user IDs. | IdP directly, such as Okta, Azure AD, OneLogin, and more. |
| **Prerequisites** | End users provisioned in Workato Identity through IAM API or the Workato UI. | One-time SAML federation between Workato Identity and the customer's existing IdP. Workato Identity acts as a broker. It doesn't replace the customer's IdP. |
| **Best for** | Server-side integrations, QA, automated testing, internal tools. | User-facing apps requiring SSO, centralized access governance, and per-user permissions. |
### Recommended authorization method by scenario {: #recommended-authorization-method-by-scenario :}
| Scenario | Recommended |
| QA / automated testing | API key |
| Security red-teaming through CI/CD | API key |
| Internal tool with builder-controlled authorization | API key |
| Custom chat UI where Workato should be invisible | API key |
| Employee portal with company SSO | OAuth 2.0 |
| Multi-tenant app serving multiple organizations | OAuth 2.0 |
| Deployment requiring IdP-governed access control | OAuth 2.0 |
| Mobile or single-page app or public client | OAuth 2.0 |
### OAuth 2.0 PKCE authorization flow {: #oauth-pkce-flow :}
OAuth clients authenticate end users through Workato Identity (`id.workato.com`) using the authorization code flow with PKCE. No client secret is required. Use the `oauth_client_id` returned when you [create an OAuth genie client](/en/workato-api/agent-studio#create-a-genie-client).
You must complete the following steps to use this authorization flow:
<Stepper>
<Step>
Generate a `code_verifier` to create a random, URL-safe string of 43–128 characters and derive the `code_challenge` as `base64url(sha256(code_verifier))`.
</Step>
<Step>
Redirect the user to the authorization endpoint:
```plaintext
https://id.workato.com/oauth/authorize?response_type=code
  &client_id=<oauth_client_id>
  &redirect_uri=<your_redirect_url>
  &scope=openid profile email
  &state=<random_state>
  &code_challenge=<code_challenge>
  &code_challenge_method=S256
</Step>
<Step>
Verify `state` matches when Workato Identity redirects to your `redirect_uri` with a `code` and the original `state`.
</Step>
<Step>
Exchange the code for tokens at `https://id.workato.com/oauth/token` with a form-encoded body. Don't send the client secret:
<api-code>
curl -X POST https://id.workato.com/oauth/token \
  -H "Content-Type: application/x-www-form-urlencoded" \
  -d "grant_type=authorization_code" \
  -d "client_id=<oauth_client_id>" \
  -d "redirect_uri=<your_redirect_url>" \
  -d "code=<authorization_code>" \
  -d "code_verifier=<code_verifier>"
</api-code>
</Step>
<Step>
Use the returned `access_token` as `Authorization: Bearer <access_token>` on Headless API calls. The token response also includes a `refresh_token` and an `id_token`.
</Step>
<Step>
Refresh the access token before it expires (`expires_in` is `3600` seconds) to avoid forcing the user through an interactive login again. Exchange the `refresh_token` at `https://id.workato.com/oauth/token` to obtain a new access token silently:
<api-code>
  -d "grant_type=refresh_token" \
  -d "refresh_token=<refresh_token>"
</api-code>
Refresh tokens are single-use and rotating: each refresh returns a new `refresh_token`. Persist the new value for the next refresh. Request the default `openid profile email` scope and don't add `offline_access`, which Workato Identity rejects.
</Step>
</Stepper>
The redirect URL must match the `oauth_redirect_url` registered on the client. Perform the code exchange in the preceding steps from a same-origin backend rather than directly in the browser. This ensures the flow is free of cross-origin (CORS) concerns and keeps token handling server-side.
## Quick reference {: #headless-api-quick-reference :}
| GET | [/api/v1/genies/:genie\_handle/chat/conversations](#list-conversations) | List a user's conversations. |
| POST | [/api/v1/genies/:genie\_handle/chat/conversations](#create-a-conversation) | Create a new conversation. |
| GET | [/api/v1/genies/:genie\_handle/chat/conversations/<br/>:conversation\_id](#get-a-conversation) | Get conversation details and state. |
| GET | [/api/v1/genies/:genie\_handle/chat/conversations/<br/>:conversation\_id/messages](#get-messages) | Get message history for a conversation. |
| POST | [/api/v1/genies/:genie\_handle/chat/conversations/<br/>:conversation\_id/messages](#send-a-message) | Send a message and receive a streaming response. |
| GET | [/api/v1/genies/:genie\_handle/chat/conversations/<br/>:conversation\_id/genie-runs/:genie\_run\_id](#reconnect-to-a-stream) | Reconnect to a message stream. |
| GET | [/api/v1/genies/:genie\_handle/chat/<br/>conversations/events](#get-events) | Get recent events. |
| POST | [/api/v1/genies/:genie\_handle/chat/conversations/<br/>:conversation\_id/skill\_approval/:call\_id](#approve-or-reject-a-skill) | Approve or reject a skill confirmation. |
| POST | [/api/v1/genies/:genie\_handle/chat/conversations/<br/>:conversation\_id/business\_approval/:call\_id](#approve-or-reject-a-business-approval) | Approve or reject a business approval request. |
| POST | [/api/v1/genies/:genie\_handle/chat/<br/>runtime\_connection/:runtime\_connection\_attempt\_id/link](#get-a-runtime-connection-link) | Get an authentication link for a runtime connection. |
| POST | [/api/v1/genies/:genie\_handle/chat/<br/>runtime\_connection/:runtime\_connection\_attempt\_id/reject](#reject-a-runtime-connection) | Reject a runtime connection request. |
| POST | [/api/v1/genies/:genie\_handle/chat/conversations/<br/>:conversation\_id/upload](#upload-a-file) | Upload a file for attachment to a message. |
| POST | [/api/v1/genies/:genie\_handle/chat/conversations/<br/>:conversation\_id/genie-runs/:genie\_run\_id/feedback](#submit-feedback) | Submit user feedback for a genie run. |
## List conversations {: #list-conversations :}
Retrieve a list of the authenticated user's conversations. Results are listed by the `created_at` timestamp in descending order.
<api-code no-copy-method>
GET /api/v1/genies/:genie_handle/chat/conversations
</api-code>
### URL parameters {: #list-conversations-url-parameters :}
| Name | Type | Description |
| genie\_handle | **string**<br>*required* | Genie handle. |
### Query parameters {: #list-conversations-query-parameters :}
| limit | **integer**<br>*optional* | Number of conversations to return. Defaults to `50`. |
| cursor | **string**<br>*optional* | Pagination cursor from a previous response. |
### Response {: #list-conversations-response :}
| list\[] | **array** | List of conversations. |
| list\[].conversation\_id | **string** | Conversation ID. |
| list\[].topic | **string** | Conversation topic. |
| list\[].last\_updated\_at | **string** | Timestamp of the last update. |
| list\[].created\_at | **string** | Timestamp when the conversation was created. |
| total\_count | **integer** | Total number of conversations. |
| cursor | **string** | Cursor for the next page of results. |
## Create a conversation {: #create-a-conversation :}
Create a new conversation with the genie.
POST /api/v1/genies/:genie_handle/chat/conversations
</api-code>
### URL parameters {: #create-a-conversation-url-parameters :}
### Response {: #create-a-conversation-response :}
| conversation\_id | **string** | ID of the new conversation. |
## Get a conversation {: #get-a-conversation :}
Retrieve the details and current state of a conversation.
GET /api/v1/genies/:genie_handle/chat/conversations/:conversation_id
</api-code>
### URL parameters {: #get-a-conversation-url-parameters :}
| conversation\_id | **string**<br>*required* | Conversation ID. |
### Response {: #get-a-conversation-response :}
| state | **string** | Current state of the conversation. One of `idle` (no active turn), `ai_running` (the model is generating), `skill_processing` (a skill is executing — including while the turn is paused on a runtime-connection authorization), or `awaiting_approval` (paused on a `skill.confirmation_required`). |
| last\_event | **object** | The most recent event in the conversation. |
## Get messages {: #get-messages :}
Retrieve message history for a conversation. Results are listed by the `created_at` timestamp in descending order.
GET /api/v1/genies/:genie_handle/chat/conversations/:conversation_id/messages
</api-code>
### URL parameters {: #get-messages-url-parameters :}
### Query parameters {: #get-messages-query-parameters :}
| limit | **integer**<br>*optional* | Number of messages to return. Defaults to `100`. |
### Response {: #get-messages-response :}
| messages\[] | **array** | List of messages. |
| messages\[].message\_id | **string** | Message ID. |
| messages\[].source | **string** | Message origin. One of `user` or `genie`. |
| messages\[].content | **string** | Text content of the message. |
| messages\[].genie\_run\_id | **string** | ID of the request/response cycle the message belongs to. |
| messages\[].created\_at | **string** | Timestamp of the message in RFC3339 format. |
| total\_count | **integer** | Total number of messages in the conversation. |
## Send a message {: #send-a-message :}
Send a user message and receive a real-time stream of events as the genie processes and responds.
POST /api/v1/genies/:genie_handle/chat/conversations/:conversation_id/messages
</api-code>
### URL parameters {: #send-a-message-url-parameters :}
### Payload {: #send-a-message-payload :}
| message | **string**<br>*required* | The user's message. Maximum 12 KB. |
| file\_id | **string**<br>*optional* | ID of a previously uploaded file to attach to this message. |
| stream | **boolean**<br>*optional* | Set to `true` to receive an SSE stream in the response. Defaults to `false`. |
### Response {: #send-a-message-response :}
When `stream` is `false`, returns HTTP 202 with the following body:
| genie\_run\_id | **string** | ID of the genie run. Use this to reconnect to the stream. |
When `stream` is `true`, the response is a stream of [Server-Sent Events](#sse-events). The stream closes when the genie finishes processing, indicated by the `processing.finished` event.
## Reconnect to a stream {: #reconnect-to-a-stream :}
Reopen the SSE stream for a specific genie run. Use this to recover events after a disconnection. Pass the ID of the last successfully received event in the `Last-Event-ID` header.
GET /api/v1/genies/:genie_handle/chat/conversations/:conversation_id/genie-runs/:genie_run_id
</api-code>
### URL parameters {: #reconnect-to-a-stream-url-parameters :}
| genie\_run\_id | **string**<br>*required* | Genie run ID, as returned by [Send a message](#send-a-message). |
### Headers {: #reconnect-to-a-stream-headers :}
| Last-Event-ID | **string**<br>*optional* | ID of the last successfully received event. The stream replays events from this point. |
### Response {: #reconnect-to-a-stream-response :}
The response is a stream of [Server-Sent Events](#sse-events).
## Get events {: #get-events :}
Retrieve recent events. Use this as a fallback to manually fetch missed events after a disconnection. Events are returned oldest first and are available for 24 hours.
GET /api/v1/genies/:genie_handle/chat/conversations/events
</api-code>
### URL parameters {: #get-events-url-parameters :}
### Query parameters {: #get-events-query-parameters :}
| since\_created\_at | **string**<br>*optional* | Lower bound (inclusive) on event creation time, as an RFC3339 timestamp (for example, `2026-05-26T12:00:00.123456Z`). Pass `next_since_created_at` from the previous response to fetch the next page. |
| conversation\_id | **string**<br>*optional* | Filter events by conversation ID. |
| limit | **integer**<br>*optional* | Page size. Defaults to `100`. |
### Response {: #get-events-response :}
| events\[] | **array** | Array of events, ordered oldest first. |
| events\[].conversation\_id | **string** | Conversation ID. |
| events\[].genie\_handle | **string** | Genie handle (string identifier, for example `gin-AaDX9axF-CNtgQn-B6`). |
| events\[].genie\_run\_id | **string** | ID of the genie run this event belongs to. |
| events\[].type | **string** | Event type. |
| events\[].event\_id | **string** | UUIDv7 identifying this event. |
| events\[].seq\_num | **integer** | Per-genie-run monotonic sequence number. |
| events\[].created\_at | **string** | Gateway-side timestamp when the event was persisted, in RFC3339 format. |
| next\_since\_created\_at | **string** | Continuation cursor. When present, pass this value as `since_created_at` on the next request to fetch the next page. |
## Approve or reject a skill {: #approve-or-reject-a-skill :}
Approve or reject a skill confirmation request. Use this when the genie emits a `skill.confirmation_required` event.
POST /api/v1/genies/:genie_handle/chat/conversations/:conversation_id/skill_approval/:call_id
</api-code>
### URL parameters {: #approve-or-reject-a-skill-url-parameters :}
| call\_id | **string**<br>*required* | Call ID from the `skill.confirmation_required` event. |
### Payload {: #approve-or-reject-a-skill-payload :}
| resolution | **string**<br>*required* | One of `approved` or `rejected`. |
| rejection\_reason | **string**<br>*optional* | Reason for rejection. Only used when `resolution` is `rejected`. |
## Approve or reject a business approval {: #approve-or-reject-a-business-approval :}
Submit an approver's decision for a business approval identified by `call_id`.
POST /api/v1/genies/:genie_handle/chat/conversations/:conversation_id/business_approval/:call_id
</api-code>
### URL parameters {: #approve-or-reject-a-business-approval-url-parameters :}
| call\_id | **string**<br>*required* | Call ID of the business approval to resolve. |
### Payload {: #approve-or-reject-a-business-approval-payload :}
## Get a runtime connection link {: #get-a-runtime-connection-link :}
Get an authentication link for a runtime connection. Use this when the genie emits a `runtime_connection.auth_required` event.
POST /api/v1/genies/:genie_handle/chat/runtime_connection/:runtime_connection_attempt_id/link
</api-code>
### URL parameters {: #get-a-runtime-connection-link-url-parameters :}
| runtime\_connection\_attempt\_id | **string**<br>*required* | Server-generated ID for the pending runtime-connection authorization attempt, as delivered in the `runtime_connection.auth_required` SSE event. |
### Response {: #get-a-runtime-connection-link-response :}
| status | **string** | One of `auth_required` or `authorized`. When `authorized`, the connection is already complete and no user action is needed. |
| auth\_link.url | **string** | Authentication URL to present to the user. Only present when `status` is `auth_required`. |
| auth\_link.expires\_at | **string** | Expiration time of the authentication URL in RFC3339 format. Only present when `status` is `auth_required`. |
| auth\_link.connector\_name | **string** | Human-readable connector label (for example, `Salesforce`, `Google Drive`). Only present when `status` is `auth_required`. |
## Reject a runtime connection {: #reject-a-runtime-connection :}
POST /api/v1/genies/:genie_handle/chat/runtime_connection/:runtime_connection_attempt_id/reject
</api-code>
### URL parameters {: #reject-a-runtime-connection-url-parameters :}
### Payload {: #reject-a-runtime-connection-payload :}
| reason | **string**<br>*optional* | Reason for rejection. |
## Upload a file {: #upload-a-file :}
Upload a file to attach to a subsequent message. Returns a `file_id` to pass in the `file_id` parameter of [Send a message](#send-a-message). The maximum file size is 20 MB.
POST /api/v1/genies/:genie_handle/chat/conversations/:conversation_id/upload
</api-code>
### URL parameters {: #upload-a-file-url-parameters :}
### Payload {: #upload-a-file-payload :}
| file | **file**<br>*required* | File data (multipart/form-data). Maximum size is 20 MB. |
### Response {: #upload-a-file-response :}
| file\_id | **string** | ID of the uploaded file. |
## Submit feedback {: #submit-feedback :}
Submit user feedback through a positive or negative reaction and an optional comment for the AI response produced by a genie run.
POST /api/v1/genies/:genie_handle/chat/conversations/:conversation_id/genie-runs/:genie_run_id/feedback
</api-code>
### URL parameters {: #submit-feedback-url-parameters :}
| genie\_run\_id | **string**<br>*required* | Genie run ID whose response the feedback is about. |
### Payload {: #submit-feedback-payload :}
| reaction | **string**<br>*required* | The user's reaction to the AI response. One of `positive` or `negative`. |
| comment | **string**<br>*optional* | Free-form comment accompanying the reaction. Maximum 10,000 characters. |
## SSE events {: #sse-events :}
You can send a message with `stream: true` to get a response with a stream of SSE covering the full lifecycle of the genie's response.
Events are persisted for 24 hours and are retrievable through the [Get events](#get-events) endpoint.
### Base event shape {: #sse-events-base-shape :}
Every event shares the following base fields:
| Field | Type | Description |
| `conversation_id` | **string** | Conversation ID. |
| `genie_handle` | **string** | Genie handle (string identifier, for example `gin-AaDX9axF-CNtgQn-B6`). |
| `genie_run_id` | **string** | ID of the genie run this event belongs to. |
| `type` | **string** | Event type. |
| `event_id` | **string** | UUIDv7 identifying this event. |
| `seq_num` | **integer** | Per-genie-run monotonic sequence number. |
| `created_at` | **string** | Gateway-side timestamp when the event was persisted, in RFC3339 format. |
### Event types {: #sse-event-types :}
| Event | Additional fields | Description |
| `processing`<br>`.started` |  | Genie has begun processing the request. |
| `processing`<br>`.finished` |  | Genie has completed processing. |
| `agent`<br>`.message` | <ul><li>`message`</li></ul> | The genie's response message. |
| `skill`<br>`.running` | <ul><li>`skill_name`</li><li>`skill_id`</li></ul> | A skill has started executing. |
| `skill`<br>`.completed` | <ul><li>`skill_name`</li><li>`skill_id`</li></ul> | A skill completed successfully. |
| `skill`<br>`.failed` | <ul><li>`skill_name`</li><li>`skill_id`</li><li>`error`</li></ul> | A skill execution failed. |
| `skill`<br>`.stopped` | <ul><li>`skill_name`</li><li>`skill_id`</li></ul> | Terminal variant emitted by some runtime versions in place of `skill.completed`. Treat it as a successful completion. |
| `skill`<br>`.confirmation`<br>`_required` | <ul><li>`call_id`</li><li>`skill_name`</li><li>`skill_id`</li><li>`skill_parameters`</li><li>`skill_`<br>`parameter_schema`</li></ul> | A skill requires user confirmation before executing. Use `call_id` with [Approve or reject a skill](#approve-or-reject-a-skill). |
| `runtime_connection`<br>`.auth_required` | <ul><li>`runtime_connection`<br>`_attempt_id`</li><li>`auth_link`</li></ul> | A skill requires the user to authenticate a connection. Use `runtime_connection`<br>`_attempt_id` with [Get a runtime connection link](#get-a-runtime-connection-link). |
| `system.ping` |  | Keep-alive heartbeat, sent roughly every 30 seconds during long-running or paused turns. Ignore it. |
| `system`<br>`.stream_interrupted` | <ul><li>`genie_run_id`</li><li>`last_seq_num`</li><li>`reason`</li><li>`retry_after_ms`</li></ul> | The server closed the stream before the turn finished (for example, during a long pause). Recover from persisted state rather than assuming the turn failed; see [Rebuild a conversation timeline](/en/agentic/agent-studio/chat-interface/headless-api-troubleshooting#rebuild-a-conversation-timeline). |
## Limitations {: #limitations :}
Headless API endpoints have the following limitations:
* [Action Board](/en/agentic/agent-studio/action-board) isn't supported
* [App Events](/en/agentic/agent-studio/app-events) aren't supported
* A genie supports a single attached client. The client-to-genie relationship is **1:1**: attaching a second client returns a `409` conflict. [Detach](/en/workato-api/agent-studio#detach-a-client-from-a-genie) the existing client first to re-point it.
## Quotas {: #limits :}
<LimitTable group="agentic" :tags="['headless-api']" className="evenly-distributed" :show-columns="['description', 'limit', 'notes']"/>
