# LINE WORKS - List records action
The List records action searches LINE WORKS and retrieves a list of all objects of the type you specify.
LINE WORKS List records action
| Input Field | Description |
| Object | Specify the object type to retrieve from LINE WORKS. Additional input fields load dynamically based on the selected object type. |
The List records action's output fields change dynamically based on the selected object type. Map the relevant datapills from the data tree for downstream steps.
