# Microsoft Graph API - Create record action
The Create record action enables you to create a new record in Microsoft Graph API, such as a user.
| Object | Select the object you plan to create. Fields load dynamically based on your selected object. |
The output fields depend on the object you select in the input. Each object returns a unique set of fields based on its type.
