# Microsoft Graph API - Delete record action
The Delete record action enables you to delete a record using its object ID.
| Object | Select the object you plan to delete. Fields load dynamically based on your selected object. |
| Item ID | Provide the unique ID of the object to delete. |
| Status | The status of the delete action. |
