# Microsoft Graph API - Search records action
The Search records action returns all records matching your search criteria.
Input field | Description |
Object | Select the object you plan to search from the drop-down menu. Fields load dynamically based on the selected object. |
The output fields depend on the object you select in the input. Each object returns a unique set of fields based on its type.
