# PlusOne Solutions
PlusOne Solutions (opens new window) is a comprehensive vendor management platform that streamlines compliance, screening, and relationship management for companies working with external vendors and contractors. The platform helps organizations manage the entire vendor lifecycle, from onboarding and compliance tracking to performance monitoring and relationship maintenance.
API ACCESS REQUIRED
You must have an active PlusOne Solutions account with API access to connect to PlusOne Solutions in Workato. Contact your PlusOne Solutions administrator to ensure API access is enabled for your account. Refer to the PlusOne Solutions API documentation (opens new window) for detailed information about available endpoints and data structures.
# How to connect to PlusOne Solutions
Click Create > Connection.
Search for and select PlusOne Solutions as your connection on the New Connection page.
Provide a Connection name that identifies which PlusOne Solutions instance Workato is connected to.
 PlusOne Solutions Connection
Select the PlusOne Solutions Environment to connect to:
- Testing - Connects to the test environment (api-test.plus1staging.net (opens new window))
- Production - Connects to the production environment (api.plus1solutions.net (opens new window))
Enter the Email address associated with your PlusOne Solutions account. This is used for authentication and audit logging.
Enter the Password for your PlusOne Solutions account.
 Last updated: 10/6/2025, 4:26:02 PM
