# Positional file tool - Create flat file (streaming) action
The Create flat file (streaming) action creates a positional flat file from streaming CSV or JSON input in Positional file tool.
Input field Description
Streaming content Enter streaming content datapills from a file connector in CSV or JSON format.
Streaming input format Select the format of the streaming input. Options are CSV or JSON.
Chunk size (MB) Select the chunk size, in MB, to stream.
Line ending Select the line ending character for the output flat file.
Merge flat file output? Select Yes or No to decide to merge all schemas with the flat file output into a single file.
Schemas Fields to define columns for the schema. Schema fields include Schemas source list, Schemas fields, Schema name, Data source, Output destination, Upload URL, and Column specification.
Output field Description
Total lines generated The total number of lines in the response flat file.
Total chunks processed The total number of chunks processed in the streaming flat file.
Status The status of the flat file response.
Last updated: 4/16/2026, 8:47:13 PM
On this page
