# Positional file tool - Parse flat file (streaming) action
The Parse flat file (streaming) action parses large positional flat files in chunks in Positional file tool.
Input field Description
File content Enter file content data pills from a connector.
Chunk size (MB) Select the chunk size, in MB, to stream.
Merge file storage output? Select Yes or No to decide to merge all schemas with the flat file output into a single file.
Output format Select the format of the output. Options are CSV or JSON.
Schemas Fields to define columns for the schema. Schema fields include Schema name, Identifier start position, Identifier length, Identifier value, Output destination, Upload URL, and Column specification.
Output field Description
Total lines processed The total number of lines processed in the response flat file.
Total chunks processed The total number of chunks processed in the streaming flat file.
Status The status of the flat file response.
Last updated: 4/16/2026, 8:47:13 PM
On this page
