# Power BI - Custom action
The Custom action allows you to build and execute an HTTP request with your Power BI connection.
| Request type | Select the HTTP method of the request, such as POST, GET, PUT, or DELETE. |
| Path | Define the API endpoint path to append to the base URI. Use an absolute URI to override the base URI if necessary. |
| URL parameters | Add any required URL parameters to refine the API call. |
| Request body parameters | Enter the JSON payload for POST or PATCH requests. |
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to subsequent steps.
Last updated: 1/2/2026, 5:56:05 PM
