# Workato Event Streams - New message trigger
The new message trigger enables you to subscribe to a specific topic in Workato. The trigger picks up all messages published to that topic, as a single trigger event.
Select the topic to configure the new message trigger
Configure the following fields:
- Message topic
- Select a topic from your existing topics, update, or create a new topic.
- When first started, this recipe should pick up events from
- Fetch trigger events from a specified time. After you run or test a recipe, you cannot change this value. Refer to Triggers to learn more about this input field.
- Set trigger conditions
- Toggle Set trigger conditions to only process trigger events matching specified conditions.
Last updated: 1/16/2026, 4:23:47 PM
