# SAP Ariba - List objects action
Use the List objects action to list objects in SAP Ariba.
COMPATIBLE APIS
The SAP Ariba connector supports multiple APIs, and each API provides access to different objects and operations. Refer to the Available APIs section to identify the APIs compatible with this action.
Input field Description
Object Specify an object to list its available records. Additional fields load dynamically based on the object you select.
The output of this action is determined by the object selected in the input. Use the data tree in the recipe editor to see all available output fields for your specific object and map them to subsequent steps.
Last updated: 11/11/2025, 5:08:44 PM
On this page
