# UKG Pro - New/updated employees trigger
This trigger picks up new or updated employees in your UKG Pro instance. Each new employee is processed as a separate job. It checks for new or updated employees once every poll interval.
Input field Description
Poll interval The frequency to check for new or updated employees.
When first started, this recipe should pick up events from Employees created after this time will be processed by the recipe. If left blank, the default date will be set to one hour before the recipe is first started. Refer to Triggers to learn more about this input field.
Output field Description
Employee fields Refer to the UKG Pro API documentation (opens new window) for more information on the employee object.
On this page
