# How-to guides - Securing Webhook events
Webhook signature verification is a recommended practice that prevents malicious actors from spoofing events or allowing your connector to reject webhooks that were tampered with. There are many known signature verification methodologies which normally involve creating a signature from the webhook event and matching that against a signature in the webhook's headers. And this guide will show you one simple example of how to do so through HubSpot's webhook V1 signature (opens new window).
TIP
This guide assumes you know the basics of creating static or dynamic webhook triggers. Please review those guides if you have not done so.
# Sample Connector - HubSpot Webhooks
webhook_payload_type: "raw", # Workato does a JSON.parse on incoming webhooks but we need to calculate the signature based on the raw payload
webhook_notification: lambda do |input, payload, extended_input_schema, extended_output_schema, headers, params, connection, webhook_subscribe_output|
original_payload = payload
client_secret = connection['client_secret']
if client_secret.present?
source_string = client_secret + original_payload # Build the string to SHA256 which is a concatenation of client secret + payload
v1_signature = source_string.encode_sha256.encode_hex
end
# If condition below verifies that the signature we calculated is the same as the X-Hubspot-Signature we got in the webhook event
if (client_secret.present? && v1_signature == headers['X-Hubspot-Signature'])
# Don't forget to parse the payload into JSON as we dictated that the payload would be `raw`
events: workato.parse_json(payload),
headers: headers,
webhook_validated: client_secret.present? ? true : false
end
end,
See the full connector in our community library (opens new window).
# Step 1 - Setting the webhook_payload_type to raw if needed
Workato's webhook gateway always attempts to parse incoming payloads as JSON. In some cases, this may cause some of the payload's details to be lost which may result in a wrong signature being created. To avoid this, you can use the key webhook_payload_type to force Workato to provide the raw payload to the webhook_notification lambda.
# Step 2 - Computing the Webhook signature
Another important part of verifying the authenticity of a webhook is to compute your own webhook signature from the incoming webhook event. This is often done through an encryption algorithm such as SHA256 or HMAC algorithms using the payload and a secret that is only known by you and the webhook provider.
end
In the case of HubSpot, we create the key to be encrypted from the payload and the client secret before encrypting it with SHA256.
# Step 3 - Comparing the generated signature with the provided one in the webhook event
The next step would be to compare your generated signature in step 2 with the signature present in the webhook event. Normally, this would be contained in the header of the webhook event which you have access to in the webhook_notification lambda.
headers: headers,
end
