# How-to guides - URL Encoded Form
This request format can be declared in any keys (execute
, acquire
, fields
etc.) in your custom connector code.
# Sample code snippet
Let's use the submit data to a form endpoint in HubSpot API (opens new window) as an example. This endpoint accepts form data in form urlencoded format.
A cURL example looks like this:
curl \
https://forms.hubspot.com/uploads/form/v2/12345/67890 \
-X POST \
-H 'Content-Type: application/x-www-form-urlencoded' \
-d 'firstname=TestContact&lastname=FormSub&[email protected]&newcustomproperty=testing&hs_context=%7B%22hutk%22%3A%2260c2ccdfe4892f0fa0593940b12c11aa%22%2C%22ipAddress%22%3A%22192.168.1.12%22%2C%22pageUrl%22%3A%22http%3A%2F%2Fdemo.hubapi.com%2Fcontact%2F%22%2C%22pageName%22%3A%22Contact%2BUs%22%2C%22redirectUrl%22%3A%22http%3A%2F%2Fdemo.hubapi.com%2Fthank-you%2F%22%7D'
This cURL command can be replicated in Workato:
title: "HubSpot",
connection: {
# Some code here
test: {
# Some code here
actions: {
submit_form: {
input_fields: lambda do
type: "string"
type: "string"
type: "string"
type: "string"
type: "string"
type: "string"
type: "string"
end,
execute: lambda do |connection, input|
post("https://forms.hubspot.com/uploads/form/v2/#{input['portal_id']}/#{input['form_guid']}").
request_body(
input.reject { |k,v| k == 'portal_id' || k == 'form_guid' }
request_format_www_form_urlencoded
end
output_fields: { ... }
triggers: {
# Some code here
object_definitions: {
# Some code here
pick_lists: {
# Some code here
methods: {
# Some code here
# Components
cURL | Workato |
curl https://forms.hubspot.com/uploads/form/v2/{portal_id}/{form_guid} -X POST | post("https://forms.hubspot.com/uploads/form/v2/#{input['portal_id']}/#{input['form_guid']}") |
-H 'Content-Type: application/x-www-form-urlencoded' | .request_format_www_form_urlencoded |
-d '{data}' | .request_body(input.reject { |k,v| k == 'portal_id' || k == 'form_guid' }) |
