# How-to guides - JSON data format
The Workato SDK's default expected data format is JSON. Action and trigger inputs will be passed as JSON payloads if no data format is specified. A JSON parser error will be shown if the SDK expected JSON and got another data format.
When you declare any HTTP request, Workato assumes the outgoing request and incoming response is in JSON. We help you append the appropriate headers Accept: application/json and Content-Type: application/json to the outgoing request.
Below we have an example of an action titled post_message. This simple action collects input from the user based on fields defined in the input_fields key in the post_message action and when the action is executed in a recipe, the execute key is run that creates a POST HTTP call to https://api.ciscospark.com/v1/messages with input as its body.
# Sample code snippet
title: 'My cisco connector',
connection: {
# Some code here
test: {
# Some code here
actions: {
post_message: {
input_fields: lambda do
end,
execute: lambda do |connection,input|
post("https://api.ciscospark.com/v1/messages", input)
end,
output_fields: lambda do
end
triggers: {
# Some code here
object_definitions: {
# Some code here
pick_lists: {
# Some code here
methods: {
# Some code here
Here we have the resultant request that is sent when the execute key above is executed. We default your Content-Type header to application/json and also format your input as key-value pairs in a JSON formatted string. This minimizes the amount of pre and post request processing that you need to do.
# Request
Now lets go through what happens when we run the post_message action that we just defined. Below we go through the POST HTTP request we send out to https://api.ciscospark.com/v1/messages (opens new window)
HEADERS AND BODY SECTIONS
POST HTTP requests are usually divided into two sections: Headers and Body. The request headers define the HTTP method and include metadata related to the request. The request body contains the actual content or payload.
# Request headers
Since no data format was declared in our action, Workato defaults to JSON and assigns Content-Type to application/json. This tells the API we sent the request to that our request body is in a JSON data format.
POST https://api.ciscospark.com/v1/messages
Accept application/json
Content-Type application/json
Authorization Bearer ---
# Request body:
This request body is generated based on the user's input and transformed into a JSON format by Workato. This request body corresponds to a user's input for the roomId field being 1234 and text field being testing.
"roomId":"1234",
"text":"testing"
# Response
Whenever you send a HTTP request, you expect a response back which contains a few components
# Response status code
The response status code is an important way to know whether your request to the API was good.
HTTP/1.1 200 OK
# Response headers
This is similar to request headers and contains metadata about the response body.
# Response body:
The response body is where the API sends the most of information in response to your request.
"id":"1",
"roomId":"1234",
"roomType":"group",
"text":"testing",
"personId":"101",
"personEmail":"[email protected]",
"created":"2017-03-26T13:28:22.131Z"
Last updated: 5/26/2025, 3:37:00 AM
