# List and Hash formulas
In addition to the basic data types (for example, string and integer), you may encounter more complex data structures that contain information about multiple items or multiple pieces of information about a single item.
You may encounter these data structures:
Formulas in Workato are added to allowlists for Ruby methods. Only allowlisted Ruby methods are supported. To request the addition of new formulas to the allowlist, submit a support ticket (opens new window).
# Lists (arrays)
Arrays are ordered, integer-indexed collections of any object. List indexing starts at 0. Lists and arrays refer to the same data structure.
In the example below, a list of integers is expressed as:
number_list = [100, 101, 102, 103, 104]
As lists are ordered, we can use the following formula to get the values. Workato only supports retrieving up to the fifth item using this syntax.
Formula Result
number_list.first 100
number_list.second 101
number_list.third 102
number_list.fourth 103
number_list.fifth 104
number_list.last 104
We can also use indexes to get corresponding values. Remember, indexes start at 0:
Formula Result
number_list[0] 100
number_list[1] 101
number_list[2] 102
number_list[3] 103
Lists in Ruby supports negative indexes.
Formula Result
number_list[-1] 104
number_list[-2] 103
number_list[-3] 102
number_list[-4] 101
Lists also support ranges as indexes. This returns another list, instead of returning only a value.
Formula Result
number_list[0..2] [100, 101, 102]
number_list[-3..-1] [102, 103, 104]
number_list[0..-2] [100, 101, 102, 103]
# Hashes
A hash is a dictionary-like collection of unique keys and their values. They are similar to Lists, but where a List uses integers as its index, a Hash allows you to use any object type. Hashes enumerate their values in the order that the corresponding keys were inserted.
Let's take the example of a hash with 2 values, with 'Acme widgets' and 10 as the values of item_name and item_quantity respectively.
line_item = { 'item_name' => 'Acme widgets', 'item_qty' => 10 }
Formula Result
line_item["item_name"] "Acme widgets"
line_item["item_qty"] 10
# Lists of hashes
Here is an example of an invoice which has multiple line items. It is represented as a list of hashes.
line_items = [
  { 'item_no': 1, 'item_name' => 'Acme widgets', 'item_qty' => 10 },
  { 'item_no': 2, 'item_name' => 'RR bearings',  'item_qty' => 99 },
  { 'item_no': 3, 'item_name' => 'Coyote tyres', 'item_qty' => 7 }
# Example list of hashes
The following is an example of a list of hashes called Contacts.
This is the Contacts list in a table form:
name email state company company_rev
Joe [email protected] CA ABC 1000
Jill [email protected] MA NBC 1000
Joan [email protected] MA NBC 10000
Jack [email protected] CA HBO 30000
This is the Contacts list in a list of hashes form.
    'name' => 'Joe',
    'email' => '[email protected]',
    'state' => 'CA',
    'company' => 'ABC',
    'company_rev' => 1000,
    'description' => { 'summary' => 'First time buyer', 'estimated_value' => 300 }
    'name' => 'Jill',
    'state' => 'MA',
    'company' => 'NBC',
    'description' => { 'summary' => 'Referral', 'estimated_value' => 500 }
    'name' => 'Joan',
    'state' => 'MA',
    'company' => 'NBC',
    'company_rev' => 10000,
    'description' => { 'summary' => 'Recurring customer', 'estimated_value' => 900 }
    'name' => 'Jack',
    'state' => 'CA',
    'company' => 'HBO',
    'company_rev' => 30000,
    'description' => { 'summary' => 'Recurring customer', 'estimated_value' => 1000 }
# List formulas
# first
This formula returns the first item in a list.
It can also be used to return the first n items in a list. In this case, the output will be formatted as a list.
# Syntax
List.first(number)
  • List - An input list.
  • number - (optional) The number of items to retrieve from the list. If not specified, the formula will return only one item.
# Sample usage
Formula Result
["One","Two","Three","Four","Five"].first() "One"
["One","Two","Three","Four","Five"].first(2) ["One","Two"]
[1,2,3,4,5].first() 1
[1,2,3,4,5].first(3) [1,2,3]
# How it works
This formula returns the first n items from a list. If n is greater than one, the output is formatted as a list.
Output datatype
If you are returning a single item (i.e. no arguments provided). The output will be formatted according to the item's datatype.
If you are returning more than one item. The output will be formatted as a list datatype.
# See also
  • last: Returns the last n items in a list.
  • where: Returns a subset of list items that meet a certain condition.
# last
This formula returns the last item in a list.
It can also be used to return the last n items in a list. In this case, the output will be formatted as a list.
# Syntax
List.last(number)
# Sample usage
Formula Result
["One","Two","Three","Four","Five"].last() "Five"
["One","Two","Three","Four","Five"].last(2) ["Four","Five"]
[1,2,3,4,5].last() 5
[1,2,3,4,5].last(3) [3,4,5]
# How it works
This formula returns the last n items from a list. If n is greater than one, the output is formatted as a list.
Output datatype
# See also
  • first: Returns the first n items in a list.
# index
Returns the index of the first item matching the given value. Returns nil if no matching items are found.
# Syntax
Input.index(value)
  • Input - An input list.
  • value - The value to search for in the list.
# Sample usage
Formula Result
[4, 5, 6, 7].index(6) 2
[4, 5, 6, 7].index(8) nil
# count
Returns the number of items in a list.
# Syntax
List.count
  • List - An input of list datatype.
# Sample usage
Formula Result
["Hello", "World", "Cat", "Dog"].count 4
["Hello", "World", ["Sub-array", "Here"]].count 3
["Hello", "World", nil, ["Sub-array", "Here"]].count 4
# where
Retrieves only the rows (hashes) which satisfy the specified WHERE condition. This formula accepts a single argument in the form of a hash with one or more key-value pairs.
The default operand for the condition is equal to (==). This formula also supports the following operands. Operands should be added to the end of key separated by a space.
Name Notation Example
Equal to (default) == leads.where('state': 'CA')
More than > leads.where('company_revenue >': 10000)
More than or equal to >= leads.where('company_revenue >=': 10000)
Less than < leads.where('company_revenue <': 10000)
Less than or equal to <= leads.where('company_revenue <=': 10000)
Not equal to != leads.where('state !=': 'CA')
Use datapills as the conditional argument
Instead of using a static value (for example, 'CA'), you can use a datapill as the conditional argument. The value of the datapill will be processed at run-time.
contacts.where(state: datapill )
# Sample usage
Example of a single where condition
contacts.where('state': 'CA') returns the following rows:
These rows will be expressed as a list of hashes:
    'name' => 'Joe',
    'state' => 'CA',
    'company' => 'ABC',
    'name' => 'Jack',
    'state' => 'CA',
    'company' => 'HBO',
Example of compound where formula
A compound WHERE formula will retrieve only the rows that matches all the conditions.
contacts.where('state': 'CA', 'company_revenue >=': 10000)
Returns the following rows:
    'name' => 'Jack',
    'state' => 'CA',
    'company' => 'HBO',
Warning - MULTIPLE CONDITIONS IN A SINGLE KEY
Only the last condition is considered when you apply multiple conditions to the same key in a compound WHERE formula. This overrides previous conditions, and can lead to unexpected outcomes.
The following example shows that applying multiple conditions for state, returns only rows that contain the second MA key:
contacts.where('state': 'CA', 'state': 'MA')
returns only rows with states that are MA:
These rows will be returned as a list of hashes.
    'name' => 'Jill',
    'state' => 'MA',
    'company' => 'NBC',
    'name' => 'Joan',
    'state' => 'MA',
    'company' => 'NBC',
Example of multiple matches
You can filter out records based on a particular field against more than 1 value. This is done by passing an array value in the WHERE condition.
contacts.where('company': ['ABC','HBO'])
This WHERE condition will return rows where the company is either ABC or HBO:
    'name' => 'Joe',
    'state' => 'CA',
    'company' => 'ABC',
    'name' => 'Jack',
    'state' => 'CA',
    'company' => 'HBO',
Example where condition with pattern matching
You can also filter out records using regex. This is done by passing a regex instead of a string.
contacts.where('name': /^Jo/)
This WHERE condition will return rows where the name starts with Jo:
    'name' => 'Joe',
    'state' => 'CA',
    'company' => 'ABC',
    'name' => 'Joan',
    'state' => 'MA',
    'company' => 'NBC',
Example where condition with pattern matching (using datapills)
You may use data pills within a regex pattern to dynamically change the string that you are matching. However, using variables in a regex pattern requires escaping within the regex expression.
For example: contacts.where(state: /#{ datapill }/)
The image below shows the method used to obtain all the 'Emails' in lookup table where the value in the 'State' column contains the string in the datapill from Salesforce, State Step 2 .
Datapill in regex expression Using datapills in regex expressions
Note: All regex metacharacters will need to be escaped if they should not be interpreted as metacharacters.
Example of chaining where conditions
If a series of WHERE conditions are chained, the formula evaluates each where condition in series.
contacts.where('state': 'CA').where('company_revenue >=': 10000) returns the following rows, which is the same as the compound where formula:
In this case, however, the chaining will result in an intermediary array:
contacts.where('state': 'CA') first returns:
And .where('company_revenue >=': 10000) filters this intermediary array further to return only:
Results will be expressed as a list of hashes:
    'name' => 'Jack',
    'state' => 'CA',
    'company' => 'HBO',
    'company_rev' => '30000'
Example of chaining not operator
You can use the WHERE formula to find the difference between two arrays by chaining a not operator. This is useful if you have two lists, an original list and an updated list, and plan to compare the two to ensure the updated list contains all values from the original list.
For example: contacts.where.not("id":updated_contacts.pluck('id')) identifies any values that are present in the original list (contacts) and missing from the updated list (updated_contacts).
# except
Returns a hash that includes everything except given keys.
hash = { a: true, b: false, c: nil }
hash.except(:c)     # => { a: true, b: false }
hash.except(:a, :b) # => { c: nil }
hash                # => { a: true, b: false, c: nil }
# pluck
Retrieves only the columns which have been specified.
# Sample usage
Example of a single column output
contacts.pluck("email") returns
email
[email protected]
[email protected]
[email protected]
[email protected]
If a single column, results will be returned as an array:
Example of a multiple column dataset
contacts.where("state ==": "CA").pluck("email", "company") returns
email company
[email protected] ABC
[email protected] NBC
[email protected] HBO
Results are returned as a list of a list:
[["[email protected]", "ABC"], ["[email protected]", "NBC"], ["[email protected]", "NBC"], ["[email protected]", "HBO"]]
Example of retrieving nested fields
This method can be used to extract nested fields. Use the [<1st-level field>,<2nd-level field>...] format to define which fields to retrieve.
contacts.pluck("email", ["description", "summary"]) returns
email summary
[email protected] First time buyer
[email protected] Referral
[email protected] Recurring customer
Results are returned as a list of lists:
  ["[email protected]", "First time buyer"],
  ["[email protected]", "Referral"],
  ["[email protected]", "Recurring customer"],
# format_map
Creates a new array of strings by applying a format to each item in the input array. You can reference input values in the format string using %{field_name} for hashes, or %s for sub-arrays and scalar values.
# Sample usage
Array of hashes
You can use format_map on an array of hashes. For example:
  { name: 'Alex',  email: '[email protected]',  company: 'ACME' },
  { name: 'Hao',   email: '[email protected]',   company: 'ACME' },
  { name: 'Kai',   email: '[email protected]',   company: 'STARK' },
  { name: 'Sasha', email: '[email protected]', company: 'ACME' }
].format_map('Name: %{name}, Email: %{email}, Company: %{company}')
This outputs an array containing a formatted string for each hash in the input:
  'Name: Alex, Email: [email protected], Company: ACME',
  'Name: Hao, Email: [email protected], Company: ACME',
  'Name: Kai, Email: [email protected], Company: STARK',
  'Name: Sasha, Email: [email protected], Company: ACME',
Nested array
You can use format_map on a nested array. For example:
  ['Alex', '[email protected]', 'ACME'],
  ['Hao', '[email protected]', 'ACME'],
  ['Kai', '[email protected]', 'STARK'],
  ['Sasha', '[email protected]', 'ACME']
].format_map('Name: %s, Email: %s, Company: %s')
This outputs an array containing a formatted string for each sub-array in the input:
Array of scalar values
You can use format_map on an array of scalar values, such as strings, integers, dates, and booleans. For example:
['Alex', 'Hao', 'Kai'].format_map('Name: %s')
This outputs an array containing a formatted string for each scalar value in the input:
  'Name: Alex',
  'Name: Hao',
  'Name: Kai'
# join
Combines all items in a list into a text string. A separator is placed between each item.
# Syntax
List.join(separator)
  • separator - The character to add between items when they are joined. If no separator is specified, the list items will be joined together.
# Sample usage
Formula Result
["Ms", "Jean", "Marie"].join("-") "Ms-Jean-Marie"
[1,2,3].join("--") "1--2--3"
["ab", "cd", "ef"].join "abcdef"
# How it works
The list items are combined into a single text string. The separator characters is added between each item.
Separator character
You can use a string of characters together as the separator argument (for example, ", ").
["Open","Pending","Closed"].join(", ") returns "Open, Pending, Closed".
# See also
  • split: Divides a string around a specified character and returns an array of strings.
# smart_join
Joins list elements into a string. Removes empty and nil values and trims any white space before joining.
# Syntax
List.smart_join(separator)
  • separator - The character to add between items when they are joined. If no separator is specified, a blank space will be used as the joining character.
# Sample usage
Formula Result
[nil, "", "Hello", " ", "World"].smart_join(" ") "Hello World"
["111 Vinewood Drive", "", "San Francisco", "CA", "95050"].smart_join(",") "111 Vinewood Drive, San Francisco, CA, 95050"
# concat
Concatenates 2 lists into a single list. Nested lists will NOT be flattened.
# Syntax
List.concat(list_to_be_joined)
  • list_to_be_joined - The other list to be concatenated with the original list input.
# Sample usage
Formula Result
["Hello", "World"].concat(["Workato", "Rocks"]) ["Hello", "World", "Workato", "Rocks"]
["Hello", "World", ["Sub-array", "Here"]].concat(["Workato", "Rocks"]) ["Hello", "World", ["Sub-array", "Here"], "Workato", "Rocks"]
["Hello", "World", nil, ["Sub-array", "Here"]].concat(["Workato", "Rocks"]) ["Hello", "World", nil, ["Sub-array", "Here"], "Workato", "Rocks"]
# reverse
Reverses the order of a list.
# Syntax
List.reverse
# Sample usage
Formula Result
["Joe", "Jill", "Joan", "Jack"].reverse ["Jack", "Joan", "Jill", "Joe"]
[100, 101, 102, 103].reverse [103, 102, 101, 100]
# sum
For integers and decimals, the numbers will be added together and the total sum obtained. For strings, the strings will be concatenated together to form a longer string.
# Syntax
List.sum
# Sample usage
Formula Result
[1, 2, 3].sum 6
[1.5, 2.5, 3].sum 7.0
["abc", "xyz"].sum "abcxyz"
# uniq
Returns a list containing unique items.
# Syntax
List.uniq
# Sample usage
Formula Result
["joe", "jack", "jill", "joe", "jack"].uniq ["joe","jack", "jill"]
[1, 2, 3, 1, 1, 3].uniq [1, 2, 3]
[1.0, 1.5, 1.0].uniq [1.0, 1.5]
# flatten
Flattens a multi-dimensional array (i.e. array of arrays) to a single dimension array.
# Syntax
List.flatten
# Sample usage
Formula Result
[[1, 2, 3], [4, 5, 6]].flatten [1, 2, 3, 4, 5, 6]
[[1, [2, 3], 3], [4, 5, 6]].flatten [1, 2, 3, 3, 4, 5, 6]
[[1, [2, 3], 9], [9, 8, 7]].flatten [1, 2, 3, 9, 9, 8, 7]
# length
Returns the number of elements in self. Returns 0 if the list is empty.
# Syntax
List.length
# Sample usage
Formula Result
[ 1, 2, 3, 4, 5 ].length 5
[{..}, {..}, {..}].length 3
[" ", nil, "", nil].length 4
[].length 0
# max
Returns largest value in an array. When comparing numbers, the largest number is returned. When comparing strings, the string with the largest ASCII value is returned.
# Syntax
List.max
# Sample usage
Formula Result
[-5, 0, 1, 2, 3, 4, 5].max 5
[-1.5, 1.5, 2, 3, 3.5].max 3.5
["cat", "dog", "rat"].max "rat"
# min
Returns smallest value in an array. When comparing numbers, the smallest number is returned. When comparing strings, the string with the smallest ASCII value is returned.
# Syntax
List.min
# Sample usage
Formula Result
[-5, 0, 1, 2, 3, 4, 5].min -5
[-1.5, 1.5, 2, 3, 3.5].min -1.5
["cat", "dog", "rat"].min "cat"
# compact
Removes nil values from array and hash.
# Sample usage
Formula Result
["foo", nil, "bar"].compact ["foo", "bar"]
{ foo: 1, bar: nil, baz: 2 }.compact { foo: 1, baz: 2 }
# Conditionals
# blank?
Checks whether the input is considered blank according to Ruby conventions. This includes:
  • Null values
  • Empty inputs
  • False booleans
  • Strings containing only whitespace
  • Non-value numbers, sometimes referred to as NaN (not a number). This is an undefined value or value that cannot be represented. For example, the result of division by zero, or a missing value.
# Syntax
Input.blank?
  • Input - An input datapill. It can be a string, number, date, datetime, boolean, array, or object datatype.
# Sample usage
Formula Result
"Any Value".blank? false
123.blank? false
0.blank? false
"".blank? true
' '.blank? true
nil.blank? true
false.blank? true
true.blank? false
[].blank? true
{}.blank? true
# How it works
If the input is considered blank according to Ruby conventions, the formula returns true. For any other data, it returns false.
# See also
  • presence: Returns the data if it exists, returns nil if it does not.
  • present?: Returns true if there is a valid input.
# include?
Checks if the string contains a specific substring, or if a list contains an element. Returns true if it does.
# Syntax
Input.include?(substring)
  • Input - A string or list input.
  • substring_or_element - The substring or element to check for.
# Sample usage
Formula Result
"Partner account".include?("Partner") true
"Partner account".include?("partner") false
["Hello", "World", ["Sub-array","Here"]"].include?("Hello") true
["Hello", "World", ["Sub-array","Here"]"].include?(["Sub-array","Here"]) true
# How it works
This formula check is the string contains a specific substring, or if a list contains a specific element. Returns true if it does, otherwise, returns false. The substring comparison is case sensitive, and the element comparison is exact match.
This function acts in an opposite manner from exclude?. The latter will return true only if the input string/list does NOT contain the stated keyword/element.
# See also
  • exclude?: Checks if the string contains a specific substring, or if a list contains an element. Returns false if it does.
# exclude?
# Syntax
Input.exclude?(substring)
# Sample usage
Formula Result
"Partner account".exclude?("Partner") false
"Partner account".exclude?("partner") true
["Hello", "World", ["Sub-array","Here"]"].include?("Hello") false
["Hello", "World", ["Sub-array","Here"]"].include?(["Sub-array","Here"]) false
# How it works
This formula check is the string contains a specific substring, or if a list contains a specific element. Returns false if it does, otherwise, returns true. The substring comparison is case sensitive, and the element comparison is exact match.
This function acts in an opposite manner from include?. The latter will return true only if the input string/list contains the stated keyword/element.
# See also
  • include?: Checks if the string contains a specific substring, or if a list contains an element. Returns true if it does.
# present?
This formula will check the input and if there is a value present, it will return true. If the input is nil, boolean false, an empty string, or an empty list, the formula will return false.
# Syntax
Input.present?
  • Input - An input datapill. It can be a string, number, date, or list datatype.
# Sample usage
Formula Result
"Any Value".present? true
123.present? true
0.present? true
"2017-04-02T12:30:00.000000-07:00".present? true
nil.present? false
"".present? false
[].present? false
# How it works
If the input is null, an empty string or an empty list, the formula will return false. For any other data, it returns true.
Evaluating a list with nil values
  • Only an empty list will return false.
[].present? returns false.
  • A list with nil and empty string will return true.
[nil,""].present? returns true.
# See also
  • blank?: Returns nil if the data does not exist or if the string consist of only white spaces.
# presence
# Syntax
Input.presence
  • Input - An input datapill. It can be a string, number, date, or datetime datatype.
# Sample usage
Formula Result
nil.presence nil
"".presence nil
"Any Value".presence "Any Value"
45.0.presence 45.0
0.presence 0
# How it works
If the input is null or an empty string, the formula will return nil. For any other data, it returns the original input data.
# See also
# Conversion
The following formulas allows you to convert data from arrays to other data types
# to_csv
Generates CSV line from an array. This handles escaping. Nil values and empty strings will also be expressed within the csv line.
# Syntax
Input.to_csv
  • Input - An input of list datatype.
# Sample usage
Formula Result
["John Smith", "No-Email", " ", nil, "555-1212"].to_csv "John Smith,No-Email, ,,555-1212"
["John Smith", "No-Email", " ", nil, 1212].to_csv "John Smith,No-Email, ,,1212"
# to_json
Converts hash or array to JSON string.
# Syntax
Input.to_json
  • Input - An input datapill. It can be a list or hash datatype.
# Sample usage
Formula Result
{"pet" => "cat", "color" => "gray"}.to_json {"pet":"cat","color":"gray"}
["1","2","3"].to_json ["1", "2", "3"]
# to_xml
Converts hash or array into XML string.
# Syntax
Input.to_xml
# Sample usage
Formula Result
{"name" => "Ken"}.to_xml(root: "user") <user><name>Ken</name></user>
[{"name" => "Ken"}].to_xml(root: "users") <users><user><name>Ken</name></user></users>
# from_xml
Converts XML string to hash.
# Syntax
Input.from_xml
  • Input - Input XML data.
# Sample usage
Converting XML string to hash
This XML string:
<?xml version=\"1.0\" encoding=\"UTF-8\" ?> <hash><foo type="integer">123</foo></hash>
represents the following XML data.
<hash>
</hash>
XML string.from_xml will return the following hash.
{ "hash":
  [ "foo":
      { "@type": "integer",
        "content!": "1"
# encode_www_form
Join hash into url-encoded string of parameters.
# Syntax
Input.encode_www_form
  • Input - An input of hash datatype.
# Sample usage
Formula Result
{"apple" => "red green", "2" => "3"}.encode_www_form "apple=red+green&2=3"
# to_param
Returns a string representation for use as a URL query string.
# Syntax
Input.to_param
# Sample usage
Formula Result
{name: 'Jake', age: '22'}.to_param "name=Jake&age=22"
# keys
Returns an array of keys from the input hash.
# Syntax
Input.keys
# Sample usage
Formula Result
{"name" => 'Jake', "age" => '22'}.keys ["name", "age"]
# values
Returns an array of values from the input hash.
# Syntax
Input.values
# Sample usage
Formula Result
{"name" => 'Jake', "age" => '22'}.values ["Jake", "22"]
# List operands
# Difference (-)
Returns the difference between two arrays, meaning a new array that is a copy of the first array without any of the items also present in the second array.
# Syntax
list - updated_list
  • - the difference/subtract operand
  • list - the original list
  • updated_list - an updated list
# Sample usage
Let's say you have two arrays, contacts and updated_contacts:
contacts = ["Ariel", "Max", "Kai", "Noam", "Tal"]
updated_contacts = ["Ariel", "Max", "Kai", "Lee", "Quinn"]
Formula Result
contacts - updated_contacts ["Noam", "Tal"]
updated_contacts - contacts ["Lee", "Quinn"]
# How it works
This operand creates an array that is the difference between the two arrays. The first example, contacts - updated_contacts, returns an array of items present in contacts but not present in updated_contacts. It's important to note that this does not simply remove duplicate items; if we reverse the order of operations, we obtain different results. For example, when we find the difference between updated_contacts and contacts, the new array contains items that are present in updated_contacts, and not present in contacts.
# See also
  • where: Returns a subset of list items that meet a certain condition. Reference the example on chaining not operands to use where to compare two lists.
# Union (&)
While Workato does not support the union (&) operand to manipulate arrays directly, you can achieve a similar result by combining the concat and uniq formulas.
# Syntax
list.concat(updated_list).uniq
  • list - a list
  • concat - concatenates two lists into a single list
  • uniq - returns a list containing unique values
# Sample usage
Formula Result
contacts.concat(updated_contacts).uniq ["Ariel", "Kai", "Lee", "Max", "Noam", "Quinn", "Tal"]
# How it works
concat concatenates two lists into a single list, and uniq returns a list containing unique items. You can combine two lists and remove any duplicate items that may appear by combining the two formulas.
Last updated: 12/17/2025, 6:17:46 PM
