url: 'https://docs.workato.com/en/mcp/mcp-servers.md'
description: >-
  MCP servers expose your API recipe and AI gateway collections to AI agents as
  tools through authenticated, cloud-based Model Context Protocol URLs.
# MCP servers
MCP servers enable you to expose endpoints to AI agents as tools or sets of tools through a remote, cloud-based [Model Context Protocol](https://modelcontextprotocol.io/introduction) (MCP) server. Each MCP server generates a unique, authenticated MCP URL. You can add this MCP URL to your LLM settings to enable an AI agent to use your MCP server tools to answer user prompts.
You can create MCP servers with API collections, project assets, or external (proxy) MCP servers as the tool source.
Watch a quick video guide: Getting started with MCP and Workato
[Video](https://www.youtube.com/embed/xwxL47rHhfs?rel=0&si=-ujcTLN91wOvADU4)
## Create an MCP server
You can create an MCP server using project assets or an API collection, or configure a proxy MCP server.
> **NEED AN EXAMPLE?**
> Review the [LLM, GitHub, and Workato Developer API](/en/getting-started/use-cases/mcp/github-developer-api-llm) use case for steps to create an MCP server integration that lets you create GitHub issues with natural-language commands in ChatGPT, Claude, or Cursor.
Watch a quick video guide: Search for leads in Salesforce with MCP
[Video](https://www.youtube.com/embed/eO-nG_q0woQ?rel=0&si=EDnWwRm7-T4dsykV)
### Create an MCP server with project assets
Use project assets as your tool source in the following scenarios:
- **The tool executes custom business logic**: You need agents to run a workflow, such as creating a GitHub issue or searching for leads in Salesforce.
- **You need to build tools specifically for agents**: You can use assets, such as skills, from your project without publishing an API collection first.
- **The action spans multiple apps or steps**: A single tool call orchestrates several systems.
Complete the following steps to create an MCP server with project assets:
1. Sign in to your Workato account.
2. Go to **AI Hub > Enterprise MCP > Custom servers** and click **\+ Create an MCP server**. Alternatively, you can create an MCP server from the **Projects** page by clicking **Create > MCP server** or pressing C+M.
3. Go to the **Start from scratch** section and click **New MCP server**. Refer to [Use a prebuilt MCP server](/en/mcp/prebuilt-mcps#use-a-prebuilt-mcp-server) if you plan to use a prebuilt MCP server template.
4. Select **Project assets** as your tool source.
   ![Select Project assets](/assets/project-assets.B_gBtpgE.png)_Select **Project assets**_
5. Use the **Project** drop-down menu to select the project where you plan to store the MCP server.
6. Select the tools you plan to use.
7. Enter a name for your MCP server in the **Server name** field.
8. Optional. Enter instructions for the LLM to understand the purpose and goals for the MCP server in the **Server instruction** field.
9. Click **Create MCP Server**. The MCP server tools, description, remote MCP URL, and additional server information displays in the **Details** tab.
   ![MCP server Details tab](/assets/mcp-tools-overview-page.2Q5AxJ3t.png)_MCP server **Details** tab admin view_
### Create an MCP server with an API collection
Use an API collection as your tool source in the following scenarios:
- **You have existing API recipes**: Your endpoints are published in an API recipe collection, and AI agents must access these endpoints as tools.
- **The endpoints are stable and well-defined**: Each endpoint maps to a single tool with clearly defined inputs and outputs.
- **You plan to reuse existing API management**: Your collection already has the authentication and access controls you need.
Complete the following steps to create an MCP with an API collection:
4. Select **API collection** as your tool source.
   ![Select API collection](/assets/api-collection.CGQye9Bl.png)_Select **API collection**_
5. Select the API collection you plan to use.
6. Enter a name for your MCP server in the **Server name** field.
7. Use the **Location to save this server** drop-down menu to select the project that contains the assets you plan to use for the MCP server, such as skills or API recipes.
   > **MCP SERVER ASSETS MUST BE IN THE SAME PROJECT**
   > You must store all assets in the same project folder. Error messages display if you select an unsupported asset type.
### Create a proxy for external MCP servers
Proxy MCP servers support the following authentication types:
- [OAuth 2.0](#oauth-20-)
- [API key header](#api-key-header)
- [API key query](#api-key-query-parameter)
- [Bearer token](#bearer-token)
- [OAuth 2.0 with client registration](#oauth-20-with-client-registration)
- [No authentication](#no-authentication)
Proxy MCP servers support cloud and on-prem connections:
- **Cloud**: MCP servers are reachable over the public internet.
- **On-prem**: MCP servers route tool calls through the existing Workato [on-prem agent](/en/on-prem/agents) (OPA) secure tunnel. OPA masks query parameter strings globally at the log level by default. You must select your [on-prem group](/en/on-prem/groups) to use this connection type.
Use an external MCP server as your tool source in the following scenarios:
- **A third-party MCP server already exists**: You plan to use vendor-provided tools.
- **You need agents to connect through Workato**: Agents use one Workato MCP URL instead of connecting directly to the external server.
> **REFRESH EXTERNAL MCP SERVER TOOLS**
> Workato detects changes to external MCP server tools but requires a builder to refresh the tools list to make the updated tools available to MCP clients.
Complete the following steps to create a proxy MCP server:
4. Select **External MCP Server** as your tool source.
   ![Select External MCP Server](/assets/tool-source.B9il0kEF.png)_Select **External MCP Server**_
5. Enter your proxy MCP server URL in the **External MCP server URL** field.
6. Use the **Authentication Type** drop-down menu to select the authentication method you plan to use:
   OAuth 2.0
   ##### OAuth 2.0
   1. Select **OAuth 2.0**.
   2. Optional. Expand **Custom Headers** and click **Add header** if you plan to use custom headers.
   3. Optional. Expand **Custom Query Parameters** and click **Add query parameter** if you plan to add query parameters to every request URL.
   4. Click **Connect**.
      > **OAUTH CLIENT ID METADATA DOCUMENT SUPPORT (CIMD)**
      > Workato registers itself with the external server's authorization server automatically. Dynamic client registration (RFC 7591) is used when available. Otherwise Workato provides the OAuth Client ID Metadata Document hosted URL for the authorization server to fetch.
   API Key (Header)
   #### API key header
   1. Select **API Key (Header)**.
   2. Enter the API key in the **API Key** field.
   3. Enter the header name in the **Custom Header Name** field. Defaults to `X-API-Key`.
   4. Optional. Expand **Custom Headers** and click **Add header** if you plan to use custom headers.
   5. Optional. Expand **Custom Query Parameters** and click **Add query parameter** if you plan to add query parameters to every request URL.
   6. Click **Connect**.
   API Key (Query Parameter)
   #### API key query parameter
   1. Select **API Key (Query Parameter)**.
   3. Optional. Enter a name for the API key in the **Query Parameter Name** field. Defaults to `api_key`.
   Bearer Token
   #### Bearer token
   1. Select **Bearer Token**.
   2. Enter the bearer token in the **Bearer Token** field.
   3. Optional. Expand **Custom Headers** and click **Add header** if you plan to use custom headers.
   4. Optional. Expand **Custom Query Parameters** and click **Add query parameter** if you plan to add query parameters to every request URL.
   5. Click **Connect**.
   OAuth 2.0 with Client Registration
   #### OAuth 2.0 with client registration
   1. Optional. Expand **Custom Headers** and click **Add header** if you plan to use custom headers.
   2. Optional. Expand **Custom Query Parameters** and click **Add query parameter** if you plan to add query parameters to every request URL.
   3. Select **OAuth 2.0 with Client Registration**.
   4. Enter your client ID in the **OAuth Client ID** field.
   5. Optional. Enter your client secret in the **OAuth Client Secret** field.
   6. Optional. Enter the OAuth scope you plan to use in the **OAuth Scopes** field. Scopes must be space separated.
   7. Optional. Enter the OAuth authorization endpoint in the **OAuth Authorization Endpoint** field. Defaults to `{server_url}/oauth/authorize`.
   8. Optional. Enter the OAuth token endpoint in the **OAuth Token Endpoint** field. Defaults to `{server_url}/oauth/token`.
   9. Click **Connect**.
   No Authentication
   #### No authentication
   1. Select **No Authentication**.
7. Enter a name for the MCP server in the **Server name** field.
8. Use the **Location to save this server** drop-down menu to select the project that contains the assets, such as skills or API recipes, that you plan to use for your MCP server.
   ![MCP proxy server Details tab](/assets/mcp-proxy-details-tab.BzOZDcSJ.png)_MCP proxy server **Details** tab admin view_
#### Refresh external MCP server tools
Complete the following steps to refresh external MCP server tools:
1. Go to **AI Hub > Enterprise MCP > Custom servers**.
2. Select the external proxy MCP server where you plan to refresh tools.
3. Go to the **Details** tab.
4. Go to the **Tools from external MCP server** section and click **Refresh tools**.
   ![Click Refresh tools](/assets/mcp-proxy-refresh-tools.D5kTvEF9.png)_Click **Refresh tools**_
