# Run test case
After you create a test case, you can use it to test your recipe's functionality.
You can run each test case manually from the list of test cases. To access this list, select a recipe and navigate to the Test cases tab.
# Run priority
Test cases run with the same priority as standard recipes. This means that some test cases run sequentially and some run simultaneously to stay within recipe concurrency limits.
# How Workato runs mocked steps
  • Input
  • Workato always evaluates the input values.
  • Step execution
  • Workato does not run the step. For example, for the step Search for tickets in Zendesk Workato does not send a request to Zendesk.
  • Step output
  • The step output is replaced with the mock output you provide for a specific step.
# How Workato handles data checks
# When checks run
  • Step input check
  • This check occurs before the step runs.
  • Step output check
  • This check occurs after the step runs.
  • Step output field check
# Check conditions for different data types
Workato always evaluates the data type when it performs a check. Depending on what you plan to check, the available set of conditions for a check varies.
  • Step input/output object checks
  • Workato compares JSON objects as objects, not as strings.
    • Available condition(s):
      • Equals
  • Output field checks
      • Equals
      • Contains
      • Starts with
      • Ends with
      • Doesn't equal
      • Doesn't contain
      • Doesn't start with
      • Doesn't end with
      • Is present
      • Is not present
# How Workato handles step failure checks
In general, test cases pass successfully in the following scenarios:
  • The test case run job is successful, and all checks are successful.
  • The test case run job failed, all checks are successful, and all steps with errors have negative (step failure) checks set up for them.
# Examples
The following example scenarios describe how Workato handles step failure checks under certain conditions:
Example 1
  • The test case run job failed on a STOP step.
  • The step inside the monitor block that failed DOES NOT have a negative (step failure) check.
  • The step inside the monitor block fails.
Overall result: The test case fails.
Example 2
  • The step inside the monitor block that failed HAS a negative (step failure) check
Overall result: The test case passes.
Example 3
  • The step inside the monitor block has a throw error mock and DOES NOT have a negative (step failure) check
Example 4
  • The step inside the Monitor block has a throw error and HAS a negative (step failure) check
# When checks fail
When a check fails, Workato stops the test case run job and does not complete additional recipe steps.
  • Recipe error
  • Because a test case run is a recipe run, it fails if there are problems in the recipe.
  • Check failed
  • The test case run fails and the job stops when any check fails.
  • When checked or mocked steps are deleted from a recipe
  • The test case run fails immediately.
    The job report displays the following error message:
    Test case contains an error: Some steps with mocks or checks were deleted from the recipe. Please update the test case or revert the recipe to the version that the test case was built for. Please fix it in the test case editor.
    EDITING A STEP
    When you edit a recipe step, Workato considers this equivalent to creating a new step and deleting the previous step. Thus, if you make changes to any of the steps in your recipe, Workato treats this as a deleted step and the check fails.
