url: 'https://docs.workato.com/en/workato-api/account-properties.md'
description: >-
  Reference for the Workato environment properties API, with endpoints to list
  properties by prefix and upsert environment properties.
# Developer API - Environment properties
Use the endpoints below to manage [environment properties](/en/features/account-properties) programmatically.
## Rate limits
Environment property resources have the following rate limits:
| Type | Resource | Quota |
| All | All [Environment properties](/en/workato-api/account-properties.html) endpoints | 60 requests per minute |
### Quick reference
| GET | [/api/properties](#list-properties-by-prefix) | Lists environment properties that matches a prefix. |
| POST | [/api/properties](#upsert-property) | Upserts environment properties. |
## List properties by prefix
Returns a list of environment properties belonging to a customer that matches a prefix. For example, if the prefix provided is `salesforce_sync.`, any environment property with a name **beginning** with 'salesforce\_sync.' will be returned.
<api-code no-copy-method>
GET https://YOUR_DATA_CENTER/api/properties
</api-code>
### Parameters
| Name | Type | Description |
| prefix | **string** _required_ | Return properties with the given prefix. E.g: `salesforce_sync.`. |
#### Sample request
<api-code>
```shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/properties?prefix=salesforce_sync.' \
</api-code>
### Response
```json
  "salesforce_sync.object_name": "Account",
  "salesforce_sync.object_field": "Id"
## Upsert property
Upserts environment properties. Matches by the names of the properties provided in the request.
POST https://YOUR_DATA_CENTER/api/properties
</api-code>
> **PROPERTY LIMITS**
> Environment properties have the following quotas:
> | Description | Quota |
> | Maximum number of environment properties per environment | 1,000 |
> | Maximum length of an environment property name | 100 characters |
> | Maximum length of an environment property value | 1,024 characters |
### Payload
| properties | **Hash** _required_ | Contains the names and values of the properties to upsert. |
#### Sample request
<api-code>
```shell
curl  -X POST https://YOUR_DATA_CENTER/api/properties \
      -d '{ "properties": { ":property_key_1": ":property_value_1", ":property_key_2": ":property_value_2" }}'
</api-code>
### Response
```json
  "success": true
