url: 'https://docs.workato.com/en/workato-api/api-client-apis.md'
description: >-
  Reference for the Workato developer API endpoints to list, create, update,
  delete, and regenerate tokens for API clients and client roles.
# Developer API - API clients
The following endpoints allow you to manage your API clients via developer APIs. This allows you to programmatically create new API clients when onboarding new teams or rotate API tokens regularly for all your API clients.
## Rate limits
API client resources have the following rate limits:
| Type | Resource | Quota |
| All | All [API client](https://docs.workato.com/workato-api/api-client-apis.html) endpoints | 60 requests per minute |
### Quick reference
| GET | [/api/developer\_api\_clients](#list-developer-api-clients) | List **Developer API Clients**. |
| POST | [/api/developer\_api\_clients](#create-developer-api-client) | Create **Developer API Client**. |
| GET | [/api/developer\_api\_clients/:id](#get-developer-api-client-by-id) | Get **Developer API Client by ID**. |
| PUT | [/api/developer\_api\_clients/:id](#update-developer-api-client) | Update **Developer API Clients**. |
| DELETE | [/api/developer\_api\_clients/:id](#delete-developer-api-client) | Delete **Developer API Client**. |
| POST | [/api/developer\_api\_clients/:id/regenerate](#regenerate-developer-api-client-token) | Regenerate **Developer API Client token**. |
| GET | [/api/developer\_api\_client\_roles](#list-developer-api-client-roles) | List **Developer API Client roles**. |
## List Developer API clients
List all Developer API clients.
<api-code no-copy-method>
GET https://YOUR_DATA_CENTER/api/developer_api_clients
</api-code>
### Query parameters
| Name | Type | Description |
| per\_page | **integer** | Number of API clients to return in a single page. Defaults to `100`. Max is `100`. |
| page | **integer** | Page number of the API clients to fetch. Defaults to `1`. |
#### Sample Request
<api-code>
```shell
curl  -X GET https://YOUR_DATA_CENTER/api/developer_api_clients \
</api-code>
### Response
```json
    "result": {
        "count": 3,
        "items": [
                "id": 40947,
                "name": "Test",
                "api_privilege_group_id": 26779,
                "created_at": "2023-02-22T01:55:35.739-08:00",
                "updated_at": "2023-02-28T01:23:18.046-08:00",
                "all_folders": false,
                "folder_ids": [
                    26138,
                    26136
                "environment_name": "Development",
                "environment_id": 3218,
                "ip_allow_list": "192.0.2.10,198.51.100.5",
                "token": {
                    "updated_at": "2023-02-22T09:55:36.427Z"
## Create a Developer API client
Create a Developer API client.
POST https://YOUR_DATA_CENTER/api/developer_api_clients
</api-code>
### Payload
| name | **String** | Name of the API client |
| api\_privilege\_group\_id | **integer** | API client role ID |
| all\_folders | **boolean** _required_ | Flag indicating whether API client has access to all folders |
| folder\_ids | **array** | Array of folder IDs. Required if `all_folders` is false. |
| environment\_name | **string** | Name of the environment. Required if your workspace has environments enabled. |
| ip\_allow\_list | **string** _optional_ | Array of IP addresses allowed to access the API client. Defaults to all IPs if not specified. |
#### Sample Request
<api-code>
```shell
curl  -X POST https://YOUR_DATA_CENTER/api/developer_api_clients \
      -d '{
            "name": ":name",
            "api_privilege_group_id": :api_privilege_group_id_value,
            "environment_name": ":environment_name",
            "all_folders": :true_or_false,
            "ip_allow_list": ":ip_allow_list"
</api-code>
### Response
```json
    "result": {
        "id": 40948,
        "name": "Test Client",
        "created_at": "2023-02-28T02:09:07.255-08:00",
        "updated_at": "2023-02-28T02:09:07.586-08:00",
        "all_folders": true,
        "token": {
            "updated_at": "2023-02-28T10:09:07.579Z",
            "value": "wrkaus-eyJhbGciOiJSUz..."
## Get a Developer API client by ID
Get a Developer API client by ID.
GET https://YOUR_DATA_CENTER/api/developer_api_clients/:id
</api-code>
### Path parameters
| id | **integer** _required_ | ID of the API Client. |
#### Sample Request
<api-code>
```shell
curl  -X GET https://YOUR_DATA_CENTER/api/developer_api_clients/:id \
</api-code>
### Response
```json
    "result": {
        "id": 40948,
        "token": {
        "user": {
            "id": 3218,
            "name": "Workato Customer Success test"
## Update a Developer API client
Update a Developer API client.
PUT https://YOUR_DATA_CENTER/api/developer_api_clients/:id
</api-code>
### Path parameters
### Payload
#### Sample Request
<api-code>
```shell
curl  -X PUT https://YOUR_DATA_CENTER/api/developer_api_clients/:id \
      -d '{
            "name": ":name",
</api-code>
### Response
```json
    "result": {
        "id": 40948,
        "token": {
        "user": {
            "id": 3218,
## Delete a Developer API client
Delete a Developer API client.
DELETE https://YOUR_DATA_CENTER/api/developer_api_clients/:id
</api-code>
### Path parameters
#### Sample Request
<api-code>
```shell
curl  -X DELETE https://YOUR_DATA_CENTER/api/developer_api_clients/:id \
</api-code>
### Response
```json
    "result": "success"
## Regenerate a Developer API Client token
Regenerates the API token for an API client. This invalidates the previous API token.
POST https://YOUR_DATA_CENTER/api/developer_api_clients/:id/regenerate
</api-code>
### Path parameters
#### Sample Request
<api-code>
```shell
curl  -X POST https://YOUR_DATA_CENTER/api/developer_api_clients/:id/regenerate \
</api-code>
### Response
```json
    "result": {
        "id": 40890,
        "name": "Test new API client",
        "created_at": "2023-01-29T22:30:12.930-08:00",
        "updated_at": "2023-02-28T02:19:16.542-08:00",
        "token": {
            "updated_at": "2023-02-28T10:19:16.530Z",
            "value": "wrkaus-eyJhbGc..."
## List Developer API client roles
List all Developer API Client roles.
GET https://YOUR_DATA_CENTER/api/developer_api_client_roles
</api-code>
#### Sample Request
<api-code>
```shell
curl  -X GET https://YOUR_DATA_CENTER/api/developer_api_client_roles \
</api-code>
### Response
```json
    "result": {
        "items": [
                "id": 26779,
                "name": "Admin",
                "created_at": "2023-01-18T04:31:03.302-08:00",
                "updated_at": "2023-02-28T01:23:01.427-08:00"
        "count": 3,
        "page": 1,
        "per_page": 100
