url: 'https://docs.workato.com/en/workato-api/lookup-tables.md'
description: >-
  Reference for the Workato lookup tables API to list, create, and delete tables
  and add, get, update, and remove rows programmatically.
# Developer API - Lookup tables
Use the following endpoints to manage [lookup tables](/en/features/lookup-tables) programmatically.
## Rate limits
Lookup table resources have the following rate limits:
| Type | Resource | Quota |
| POST | Delete lookup tables in batch: [/api/lookup\_tables/batch\_delete](/en/workato-api/lookup-tables.html#lut-delete) | 1 request per second |
| All | All other [Lookup tables](workato-api/lookup-tables.html) endpoints | 60 requests per minute |
### Quick reference
| GET | [/api/lookup\_tables](/en/workato-api/lookup-tables#list-lookup-tables) | List tables. |
| GET | [/api/lookup\_tables/:lookup\_table\_id/rows](/en/workato-api/lookup-tables#list-rows) | List rows. |
| GET | [/api/lookup\_tables/:lookup\_table\_id/lookup](/en/workato-api/lookup-tables#lookup-row) | Look up a row. |
| GET | [/api/lookup\_tables/:lookup\_table\_id/rows/:row\_id](/en/workato-api/lookup-tables#get-row) | Get a row. |
| POST | [/api/lookup\_tables/:lookup\_table\_id/rows](/en/workato-api/lookup-tables#add-row) | Add a row. |
| POST | [/api/lookup\_tables](#lut-create) | Create a new lookup table. |
| POST | [/api/lookup\_tables/batch\_delete](#lut-delete) | Delete lookup tables in batch. |
| PUT | [/api/lookup\_tables/:lookup\_table\_id/rows/:row\_id](/en/workato-api/lookup-tables#update-row) | Update a row. |
| DELETE | [/api/lookup\_tables/:lookup\_table\_id/rows/:row\_id](/en/workato-api/lookup-tables#delete-row) | Delete a row. |
## List lookup tables
Returns a list of lookup tables belonging to a customer. Workato includes the `project_id` of the project to which the lookup table belongs in the response.
<api-code no-copy-method>
GET https://YOUR_DATA_CENTER/api/lookup_tables
</api-code>
### Parameters
| Name | Type | Description |
| page | **integer** | Page number. Defaults to 1. |
| per\_page | **integer** | Page size. Defaults to 100 (maximum is 100). |
### Sample request
<api-code>
```shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/lookup_tables' \
</api-code>
### Response
```json
    "id": 1315,
    "name": "lookup_table4",
    "schema":
    "[{\"control_type\":\"text\",\"label\":\"code\",\"name\":\"col1\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"name\",\"name\":\"col2\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"col3\",\"name\":\"col3\",\"type\":\"string\",\"sticky\":false},{\"control_type\":\"text\",\"label\":\"col4\",\"name\":\"col4\",\"type\":\"string\",\"sticky\":false},{\"control_type\":\"text\",\"label\":\"col5\",\"name\":\"col5\",\"type\":\"string\",\"sticky\":false}]",
    "created_at": "2022-05-20T11:54:26.934-07:00",
    "updated_at": "2022-05-20T11:54:26.934-07:00",
    "project_id": "523144"
## List rows
Returns a lists of rows from the lookup table. Supports filtering and pagination.
GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows
</api-code>
### URL parameters
| lookup\_table\_id | **integer** _required_ | Lookup table id |
### Query parameters
| per\_page | **integer** | Page size. Defaults to 500 (maximum is 1000). |
| by`[<col name>]` | **string** | Filter criteria. The column name should be provided as follows: `by[<col name>]`. To match by multiple columns, provide multiple parameters. Refer to the sample request for more details. When not supplied, all rows are returned. |
### Sample request
#### Request 1: list rows
<api-code>
```shell
curl  -X GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows \
</api-code>
#### Request 2: filter and list rows
<api-code>
```shell
curl  -X GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows?by[code]=:by_code_value \
</api-code>
### Response
#### Response 1: list rows
```json
        "id": 941,
        "data": {
          "code": "IND",
          "name": "India",
          "col3": null,
          "col4": null,
          "col5": null
        "created_at": "2022-06-15T11:50:32.986-07:00",
        "updated_at": "2022-06-15T11:50:40.986-07:00"
        "id": 942,
        "data": {
          "code": "US",
          "name": "United States",
          "col3": null,
          "col4": null,
          "col5": null
        "created_at": "2022-05-20T11:50:32.986-07:00",
        "updated_at": "2022-05-20T11:50:40.986-07:00"
#### Response 2: filter and list rows
```json
        "id": 942,
        "data": {
          "code": "US",
          "col3": null,
          "col4": null,
          "col5": null
## Lookup a row
Finds the first row matching the given criteria in the lookup table. Returns a 404 when the lookup fails.
GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/lookup
</api-code>
### URL parameters
| by`[<col name>]` | **string** _required_ | Lookup criteria. The column name should be provided as follows: `by[<col name>]`. To match by multiple columns, provide multiple parameters. Refer to the sample request for more details. |
#### Sample request
<api-code>
```shell
curl  -X GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id?by[code]=:by_code_value \
</api-code>
### Response
```json
  "id": 942,
  "data": {
    "code": "US",
    "col3": null,
    "col4": null,
    "col5": null
## Get a row
Get a row from the lookup table.
</api-code>
### URL parameters
| row\_id | **integer** _required_ | Row id |
#### Sample request
<api-code>
```shell
curl  -X GET https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id \
</api-code>
### Response
```json
  "id": 942,
  "data": {
    "code": "US",
    "col3": null,
    "col4": null,
    "col5": null
## Add a row
Adds a row to the lookup table.
POST https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows
</api-code>
### URL parameters
### Payload
| data | **Hash** _required_ | The hash contains the data for the new row. |
#### Sample request
<api-code>
```shell
curl  -X POST https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows \
      -d '{ "data": { ":column_name_1": ":column_value_1", ":column_name_2": ":column_value_2" }}'
</api-code>
### Response
```json
  "id": 942,
  "data": {
    "code": "USA",
    "col3": null,
    "col4": null,
    "col5": null
  "updated_at": "2022-05-20T11:50:32.986-07:00"
## Create a new lookup table
Create a new lookup table. Depending on your requirements, you can choose to make the lookup table available for general access across your workspace or limit its scope to a specific project.
</api-code>
### Payload
| name | **string** _required_ | Provide a name for your new lookup table. |
| project\_id | **integer** _optional_ | Specify a `project_id` to scope the lookup table to a specific project. If you do not provide a `project_id`, the lookup table's scope is global. Use the [list projects](/en/workato-api/folders#list-projects) API to obtain a list of projects in your workspace. |
| schema | **hash** _required_ | Determine the structure of your lookup table by supplying a schema and specifying the name of each of the columns in your table, for example: `[{ "label": "Name" }]`. Lookup tables support a maximum of ten columns. |
### Sample request
<api-code>
```shell
curl  -X POST https://YOUR_DATA_CENTER/api/lookup_tables \
      -d '{
            "lookup_table": {
              "name": ":name",
              "project_id": :project_id_value,
              "schema": [{ "label": ":label_1" }, { "label": ":label_2" }]
</api-code>
#### Response
```json
    "id": 2372,
    "name": "Contacts",
    "schema": "[{\"control_type\":\"text\",\"label\":\"ID\",\"name\":\"col1\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Name\",\"name\":\"col2\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"CSM\",\"name\":\"col3\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Email\",\"name\":\"col4\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Phone number\",\"name\":\"col5\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Priority\",\"name\":\"col6\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Tier\",\"name\":\"col7\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Notes\",\"name\":\"col8\",\"type\":\"string\",\"sticky\":true},{\"control_type\":\"text\",\"label\":\"Created at\",\"name\":\"col9\",\"type\":\"string\",\"sticky\":false},{\"control_type\":\"text\",\"label\":\"Updated at\",\"name\":\"col10\",\"type\":\"string\",\"sticky\":false}]",
    "project_id": 4321,
    "created_at": "2023-09-11T11:31:35.335-07:00",
    "updated_at": "2023-09-11T11:31:35.335-07:00"
## Delete lookup tables in batch
Use this endpoint to delete lookup tables in batch.
POST https://YOUR_DATA_CENTER/api/lookup_tables/batch_delete
</api-code>
### Payload
| ids | **hash** _required_ | Include the ID(s) of the lookup table(s) you plan to delete. |
### Sample request
<api-code>
```shell
curl  -X POST https://YOUR_DATA_CENTER/api/lookup_tables/batch_delete \
      -d '{ "ids": [:id_1, :id_2] }'
</api-code>
#### Response
```json
    "data": {"deleted": [1234, 1235, 1236] },
    "errors": []
## Update a row
Updates a row in the lookup table.
PUT https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id
</api-code>
### URL parameters
### Payload
| data | **Hash** _required_ | The hash containing the data for the updated row. Only the columns provided are updated. |
#### Sample request
<api-code>
```shell
curl  -X PUT https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id \
      -d '{ "data": { ":column_name": ":column_value" }}'
</api-code>
### Response
```json
  "id": 942,
  "data": {
    "code": "US",
    "col3": null,
    "col4": null,
    "col5": null
## Delete a row
Delete a row from the lookup table
DELETE https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id
</api-code>
### URL parameters
#### Sample request
<api-code>
```shell
curl  -X DELETE https://YOUR_DATA_CENTER/api/lookup_tables/:lookup_table_id/rows/:row_id \
</api-code>
### Response
```json
  "success": true
