url: 'https://docs.workato.com/en/workato-api/mcp-servers.md'
description: >-
  Reference for the Workato MCP servers API to create, update, and delete
  servers, assign tools and user groups, manage server policies, and manage
  hashed tokens.
# Developer API - MCP servers
Use this resource to manage MCP (Model Context Protocol) servers programmatically.
> **TOKEN AND HASHED TOKEN AUTHENTICATION**
> `hashed_token` is the default authentication type for token-based MCP servers. The `token` authentication type is considered **legacy**. Existing servers using `token` continue to work, but new servers use `hashed_token`. Refer to [Create a hashed token](#create-a-hashed-token) for more information on how to manage tokens on `hashed_token` servers.
### Quick reference
| GET | [/api/mcp/mcp\_servers](#list-mcp-servers) | List MCP servers. |
| POST | [/api/mcp/mcp\_servers](#create-an-mcp-server) | Create an MCP server. |
| GET | [/api/mcp/mcp\_servers/:handle](#get-mcp-server-details) | Retrieve MCP server details. |
| PUT | [/api/mcp/mcp\_servers/:handle](#update-an-mcp-server) | Update an MCP server. |
| DELETE | [/api/mcp/mcp\_servers/:handle](#delete-an-mcp-server) | Delete an MCP server. |
| POST | [/api/mcp/mcp\_servers/:handle/token\_renew](#renew-mcp-server-authentication-token) | Renew MCP server authentication token. |
| POST | [/api/mcp/mcp\_servers/:mcp\_server\_handle/tokens](#create-a-hashed-token) | Create a hashed token. |
| DELETE | [/api/mcp/mcp\_servers/:mcp\_server\_handle/tokens/:id](#delete-a-hashed-token) | Delete a hashed token. |
| POST | [/api/mcp/mcp\_servers/:mcp\_server\_handle/tokens/:id/refresh](#refresh-a-hashed-token) | Refresh a hashed token. |
| POST | [/api/mcp/mcp\_servers/:handle/assign\_tools](#assign-tools-to-an-mcp-server) | Assign tools to an MCP server. |
| POST | [/api/mcp/mcp\_servers/:handle/assign\_user\_groups](#assign-user-groups-to-an-mcp-server) | Assign user groups to an MCP server. |
| POST | [/api/mcp/mcp\_servers/:handle/remove\_user\_groups](#remove-user-groups-from-an-mcp-server) | Remove user groups from an MCP server. |
| PUT | [/api/mcp/mcp\_servers/:handle/update\_folder](#move-mcp-server-to-a-different-folder) | Move an MCP server to a different folder. |
| GET | [/api/mcp/mcp\_servers/:mcp\_server\_handle/server\_policies](#get-server-policy-configuration) | Retrieve the server policy configuration. |
| PUT | [/api/mcp/mcp\_servers/:mcp\_server\_handle/server\_policies](#update-server-policy-configuration) | Update the server policy configuration. |
| GET | [/api/mcp/mcp\_servers/:mcp\_server\_handle/tools](#list-tools-for-an-mcp-server) | List tools for an MCP server. |
| PUT | [/api/mcp/mcp\_servers/:mcp\_server\_handle/tools/:id](#update-tool-description) | Update the tool description for an MCP. |
| DELETE | [/api/mcp/mcp\_servers/:mcp\_server\_handle/tools/:id](#delete-a-tool) | Delete a tool. |
| GET | [/api/mcp/user\_groups](#list-identity-provider-user-groups) | List identity provider user groups. |
| GET | [/api/mcp/mcp\_servers/:mcp\_server\_handle/access\_assignments](#list-mcp-access-assignments) | List MCP access assignments. |
| POST | [/api/mcp/mcp\_servers/:mcp\_server\_handle/access\_assignments](#create-an-mcp-access-assignment) | Create an MCP access assignment. |
| GET | [/api/mcp/mcp\_servers/:mcp\_server\_handle/access\_assignments/:id](#get-an-mcp-access-assignment) | Retrieve an MCP access assignment. |
| PUT | [/api/mcp/mcp\_servers/:mcp\_server\_handle/access\_assignments/:id](#update-an-mcp-access-assignment) | Update an MCP access assignment. |
| DELETE | [/api/mcp/mcp\_servers/:mcp\_server\_handle/access\_assignments/:id](#delete-an-mcp-access-assignment) | Delete an MCP access assignment. |
## List MCP servers
Returns a list of MCP servers in the workspace.
<api-code no-copy-method>
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers
</api-code>
### Query parameters
| Name | Type | Description |
| project\_id | **number** _optional_ | Filter by project ID. |
| folder\_id | **number** _optional_ | Filter by folder ID. |
| authentication\_method | **string** _optional_ | Filter by authentication method. Accepted values: `hashed_token`, `token` (legacy), `workato_idp`. |
| page | **number** _optional_ | Page number. Defaults to 1. |
| per\_page | **number** _optional_ | Number of items per page. Maximum is 50. |
#### Sample request
<api-code>
```shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers?folder_id=:folder_id_value' \
</api-code>
#### Sample response
```json
    "data": [
            "id": 1001,
            "name": "Sales Tools MCP Server",
            "description": "Provides CRM and deal management tools for AI clients",
            "folder_id": 27180380,
            "project_id": 13595198,
            "authentication_method": "hashed_token",
            "tools_count": 5
            "id": 1002,
            "name": "HR Automation Server",
            "description": "HR onboarding and employee management tools",
            "authentication_method": "workato_idp",
            "tools_count": 3
    "count": 2,
    "page": 1,
    "per_page": 50
## Create an MCP server
Creates a new MCP server in the workspace.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers
</api-code>
### Payload
| name | **string** _required_ | Server name. |
| folder\_id | **number** _required_ | Folder ID for the MCP server. |
| description | **string** _optional_ | Server description. |
| asset\_id | **number** _optional_ | API collection ID. Omit to create a project asset server. |
| tools | **array of objects** _optional_ | Tools to assign to the server at creation. Each object requires `trigger_application` (string) and `id` (string). `id` is a number when used with `workato_recipe_function` and `workato_api_platform` tools. `id` is a string handle when used with `workato_genie` tools. |
> **HASHED TOKEN AS DEFAULT AUTH TYPE**
> MCP servers use `hashed_token` as the default `auth_type` unless you specify a different authentication type. Use the [MCP hashed tokens](#create-a-hashed-token) endpoints to manage tokens on a `hashed_token` server.
#### Sample request
<api-code>
```shell
curl  -X POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers \
      -d '{
            "name": ":name",
            "description": ":description",
            "folder_id": :folder_id_value,
            "tools": [
                "trigger_application": ":trigger_application",
                "id": ":tool_id"
</api-code>
```json
    "data": {
        "id": 1001,
        "asset_type": "api_collection",
        "logo_url": "https://www.workato.com/images/mcp-server-logo.png",
        "tools_count": 1,
        "mcp_url": "https://www.workato.com/mcp/servers/sales-tools-mcp-server?token=abc123xyz",
        "auth_type": "hashed_token",
        "idp_user_group_ids": [],
        "api_collection": null,
        "created_at": "2025-10-15T13:41:05.207-07:00",
        "updated_at": "2025-10-15T13:41:05.207-07:00"
## Get MCP server details
Retrieves details for a specific MCP server.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle
</api-code>
### URL parameters
| handle | **string** _required_ | MCP server handle. You can find the `mcp_server_handle` in the URL when you go to **AI Hub > Enterprise MCP > Custom servers** and select the MCP server you plan to use. For example, your MCP server handle is `mcps-AxbxNxNz-wsB-SM` if the URL is `https://app.workato.com/mcp/mcps-AxbxNxNz-wsB-SM/overview`. |
#### Sample request
<api-code>
```shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle' \
</api-code>
```json
    "data": {
        "id": 1001,
        "tools_count": 5,
        "updated_at": "2025-10-16T09:22:11.100-07:00"
## Update an MCP server
Updates an existing MCP server.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle
</api-code>
### URL parameters
### Payload
| name | **string** _optional_ | Server name. |
| auth\_type | **string** _optional_ | Authentication type. Accepted values: `hashed_token` (default), `token` (legacy), `workato_idp`. |
| idp\_user\_group\_ids | **array of strings** _optional_ | Identity provider user group IDs that have access to the server. Only applicable when `auth_type` is `workato_idp`. |
| folder\_id | **number** _optional_ | Target folder ID to move the server. |
> **LEGACY AUTH TYPE**
> Workato retains the `token` `auth_type` for backward compatibility. New servers should use `hashed_token`. Create token profiles with the [MCP hashed tokens](#create-a-hashed-token) endpoints to switch an existing server's `auth_type` to `hashed_token`. `hashed_token` servers use individually named, revocable token profiles instead of a single server-level token.
#### Sample request
<api-code>
```shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle' \
      -d '{
            "name": ":name",
            "auth_type": ":auth_type"
</api-code>
```json
    "data": {
        "id": 1001,
        "name": "Sales & CRM Tools MCP Server",
        "description": "Provides CRM, deal management, and pipeline tools for AI clients",
        "tools_count": 5,
        "updated_at": "2025-10-17T11:05:33.812-07:00"
## Delete an MCP server
Deletes an MCP server.
DELETE https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle
</api-code>
### URL parameters
#### Sample request
<api-code>
```shell
curl  -X DELETE 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle' \
</api-code>
Returns `204 No Content` on success.
## Renew MCP server authentication token
Generates a new authentication token for an MCP server and invalidates the previous token. Use this endpoint to rotate credentials after a security event or as part of a regular credential rotation policy.
> **LEGACY ENDPOINT**
> This endpoint applies to servers using the legacy `token` auth type, which carry a single server-level token. Use [Refresh a hashed token](#refresh-a-hashed-token) for `hashed_token` servers, which operates on an individual, named token profile.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/token_renew
</api-code>
### URL parameters
#### Sample request
<api-code>
```shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/token_renew' \
</api-code>
Returns the updated MCP server object with the new `mcp_url` containing the refreshed token.
```json
    "data": {
        "id": 1001,
        "tools_count": 5,
        "mcp_url": "https://www.workato.com/mcp/servers/sales-tools-mcp-server?token=newtoken789",
        "auth_type": "token",
        "updated_at": "2025-10-18T08:00:00.000-07:00"
## MCP hashed tokens
MCP hashed token endpoints manage individual, named token profiles for MCP servers with `hashed_token` as the `auth_type`. This is an update from the legacy `token` auth type in which a single server-level token is managed through [token renewal](#renew-mcp-server-authentication-token). `hashed_token` supports up to 50 named, independently revocable token profiles per server.
### Create a hashed token
Creates a token profile for a server with `hashed_token` as the `auth_type`.
> MCP servers support a maximum of 50 active hashed tokens.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens
</api-code>
#### URL parameters
| mcp\_server\_handle | **string** _required_ | MCP server handle. You can find the `mcp_server_handle` in the URL when you go to **AI Hub > Enterprise MCP > Custom servers** and select the MCP server you plan to use. For example, your MCP server handle is `mcps-AxbxNxNz-wsB-SM` if the URL is `https://app.workato.com/mcp/mcps-AxbxNxNz-wsB-SM/overview`. |
#### Payload
| name | **string** _required_ | Token profile name. Must be non-blank, no longer than 100 characters, and case-insensitively unique among the server's active tokens. |
#### Additional constraints
> This endpoint is only available for `hashed_token` servers. Calling this endpoint on a `token` or `workato_idp` server returns an error.
#### Sample request
<api-code>
```shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens' \
      -d '{
            "name": ":name"
</api-code>
Returns `201 Created` with the token profile at the response root rather than nested under `data`.
```json
    "id": 731,
    "name": "Production token",
    "created_at": "2026-07-10T10:00:00.000Z",
    "created_by": {
        "id": 42,
        "full_name": "Example User"
    "token_first_symbols": "abc",
    "token_last_symbols": "wxyz",
    "plain_token": "<plain_token>"
> **PLAIN TOKEN IS SHOWN ONCE**
> `plain_token` is returned only at creation and can't be retrieved later. Store the token securely. You can use the [refresh the token](#refresh-a-hashed-token) endpoint to generate a new token if needed.
### Delete a hashed token
Deleting a hashed token doesn't remove it from the database. The hashed token profile is marked as inactive. The token immediately stops working and can no longer authenticate MCP requests.
DELETE https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens/:id
</api-code>
#### URL parameters
| id | **number** _required_ | Token profile ID. |
#### Sample request
<api-code>
```shell
curl  -X DELETE 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens/:id' \
</api-code>
Returns `200 OK` with an empty response body.
This endpoint is available only for `hashed_token` servers. Deleted profiles no longer appear in the server's `mcp_profiles` array.
### Refresh a hashed token
Invalidates the current token value for a profile and returns a fresh plain token.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens/:id/refresh
</api-code>
#### URL parameters
| id | **number** _required_ | Active token profile ID. |
#### Sample request
<api-code>
```shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tokens/:id/refresh' \
</api-code>
Returns `200 OK`. The response has the same root-level shape as [token creation](#create-a-hashed-token-sample-response) and contains the `plain_token`, `token_first_symbols`, and `token_last_symbols`.
```json
    "id": 731,
    "created_by": {
        "id": 42,
    "token_first_symbols": "def",
    "token_last_symbols": "uvwx",
    "plain_token": "<new_plain_token>"
This endpoint is available only for `hashed_token` servers. The returned `plain_token` is exposed only in this response. Store the token securely as you can't retrieve it later.
## Assign tools to an MCP server
Assigns one or more tools to an MCP server. Tools already assigned to the server aren't duplicated.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/assign_tools
</api-code>
### URL parameters
### Payload
| tools | **array of objects** _required_ | Tools to assign. Each object requires `trigger_application` (string) and `id` (string). |
#### Sample request
<api-code>
```shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/assign_tools' \
      -d '{
            "tools": [
                "trigger_application": ":trigger_application_1",
                "id": ":tool_id_1"
                "trigger_application": ":trigger_application_2",
                "id": ":tool_id_2"
</api-code>
Returns the updated MCP server object.
```json
    "data": {
        "id": 1001,
        "tools_count": 7,
        "updated_at": "2025-10-18T09:15:22.000-07:00"
## Assign user groups to an MCP server
Assigns identity provider user groups to an MCP server. Only applicable when the server's `auth_type` is `workato_idp`.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/assign_user_groups
</api-code>
### URL parameters
### Payload
| idp\_user\_group\_ids | **array of strings** _required_ | IDs of the user groups to add. |
#### Sample request
<api-code>
```shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/assign_user_groups' \
      -d '{
            "idp_user_group_ids": [":user_group_id_1", ":user_group_id_2"]
</api-code>
Returns the updated MCP server object with the assigned user group IDs reflected in `idp_user_group_ids`.
```json
    "data": {
        "id": 1002,
        "asset_type": "project_asset",
        "tools_count": 3,
        "mcp_url": "https://www.workato.com/mcp/servers/hr-automation-server?token=hrtoken456",
        "auth_type": "workato_idp",
        "idp_user_group_ids": ["group-abc123", "group-def456"],
        "created_at": "2025-10-15T10:00:00.000-07:00",
        "updated_at": "2025-10-18T10:30:00.000-07:00"
## Remove user groups from an MCP server
Removes identity provider user groups from an MCP server.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/remove_user_groups
</api-code>
### URL parameters
### Payload
| idp\_user\_group\_ids | **array of strings** _required_ | IDs of the user groups to remove. |
#### Sample request
<api-code>
```shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/remove_user_groups' \
      -d '{
            "idp_user_group_ids": [":user_group_id"]
</api-code>
Returns the updated MCP server object with the specified groups removed from `idp_user_group_ids`.
```json
    "data": {
        "id": 1002,
        "tools_count": 3,
        "idp_user_group_ids": ["group-def456"],
        "updated_at": "2025-10-18T11:00:00.000-07:00"
## Move MCP server to a different folder
Moves an MCP server to a specified folder.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/update_folder
</api-code>
### URL parameters
### Payload
| folder\_id | **number** _required_ | Target folder ID. |
#### Sample request
<api-code>
```shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:handle/update_folder' \
      -d '{
</api-code>
Returns the updated MCP server object with the new `folder_id` reflected in `created_at` and `updated_at` timestamps.
```json
    "data": {
        "id": 1002,
        "tools_count": 3,
        "updated_at": "2025-10-18T12:00:00.000-07:00"
## Get server policy configuration
Retrieves the security policy configuration for an MCP server, including rate limits, usage limits, Classless Inter-Domain Routing (CIDR), and IP addresses.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/server_policies
</api-code>
### URL parameters
#### Sample request
<api-code>
```shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/server_policies' \
</api-code>
```json
    "id": 501,
    "mcp_server_id": 1001,
    "rate_limits": {
        "per_minute": 60
    "quota_limits": {
        "per_day": 10000
    "ip_allow_list": ["203.0.113.0/24"],
    "ip_deny_list": [],
## Update server policy configuration
Updates the security policy configuration, including IP for an MCP server.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/server_policies
</api-code>
### URL parameters
### Payload
| mcp\_server\_policy | **object** _required_ | Policy configuration object. |
| mcp\_server\_policy\[rate\_limits\] | **object** _optional_ | Rate limit configurations. |
| mcp\_server\_policy\[quota\_limits\] | **object** _optional_ | Quota limits configurations. |
| mcp\_server\_policy\[ip\_allow\_list\] | **array of strings** _optional_ | IP addresses or CIDR ranges to allow. |
| mcp\_server\_policy\[ip\_deny\_list\] | **array of strings** _optional_ | IP addresses or CIDR ranges to deny. |
#### Sample request
<api-code>
```shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/server_policies' \
      -d '{
            "mcp_server_policy": {
              "rate_limits": { "per_minute": :per_minute_value },
              "quota_limits": { "per_day": :per_day_value },
              "ip_allow_list": [":ip_allow_1", ":ip_allow_2"],
              "ip_deny_list": []
</api-code>
```json
    "id": 501,
    "rate_limits": {
        "per_minute": 30
    "quota_limits": {
        "per_day": 5000
    "ip_allow_list": ["203.0.113.0/24", "198.51.100.42"],
    "ip_deny_list": [],
    "updated_at": "2025-10-18T14:00:00.000-07:00"
## List tools for an MCP server
Returns a paginated list of tools assigned to an MCP server.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools
</api-code>
### URL parameters
| vua\_required | **boolean** _optional_ | Filter by whether Verified User Access (VUA) is required. |
| search | **string** _optional_ | Search term to filter tools by name. |
| per\_page | **number** _optional_ | Number of items per page. Defaults to 100. Maximum is 100. |
#### Sample request
<api-code>
```shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools' \
</api-code>
```json
    "data": [
            "id": 3001,
            "name": "Create Salesforce Lead",
            "description": "Creates a new lead record in Salesforce CRM",
            "trigger_application": "workato_api_platform",
            "action_applications": ["salesforce"],
            "flow_id": 66870001,
            "vua_required": false
            "id": 3002,
            "name": "Send Deal Notification",
            "description": "Sends a Slack notification when a deal stage changes",
            "trigger_application": "workato_recipe_function",
            "action_applications": ["slack"],
            "flow_id": 66870002,
            "vua_required": true
    "count": 2,
    "page": 1,
    "per_page": 100
## Update tool description
Updates the description of a tool within an MCP server. This modifies the description shown to AI clients without affecting the underlying recipe or API endpoint.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools/:id
</api-code>
### URL parameters
| id | **number** _required_ | Tool ID. |
### Payload
| description | **string** _optional_ | New description for the tool. |
#### Sample request
<api-code>
```shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools/:id' \
      -d '{
</api-code>
```json
    "id": 3001,
    "description": "Creates a new lead record in Salesforce CRM with name, email, and company details",
## Delete a tool
Removes a tool from an MCP server.
> **API ENDPOINTS CAN'T BE DELETED**
> Only tools backed by recipe functions or genies can be deleted. Attempting to delete an API endpoint tool returns a `400 Bad Request` error.
DELETE https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools/:id
</api-code>
### URL parameters
#### Sample request
<api-code>
```shell
curl  -X DELETE 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/tools/:id' \
</api-code>
## List identity provider user groups
Returns a paginated list of identity provider user groups available in the workspace. Use the group IDs from this response when assigning access to MCP servers that use `workato_idp` authentication.
GET https://YOUR_DATA_CENTER/api/mcp/user_groups
</api-code>
#### Sample request
<api-code>
```shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/user_groups' \
</api-code>
```json
    "data": [
            "id": "group-abc123",
            "name": "Sales Team",
            "users_count": 24,
            "created_at": "2025-01-10T08:00:00.000Z",
            "updated_at": "2025-09-15T12:30:00.000Z"
            "id": "group-def456",
            "name": "HR Admins",
            "users_count": 6,
            "updated_at": "2025-08-20T10:00:00.000Z"
    "count": 2,
    "page": 1,
    "per_page": 100
## MCP access assignments
MCP access assignments control tool-level role-based access control (RBAC) for an MCP server. Each assignment grants a single identity provider user or user group access to either all tools on the MCP server or a specific set of tools.
> **REQUIREMENTS AND LIMITATIONS**
> - Access assignments work only with MCP servers that use `workato_idp` as the `auth_type`.
> - Access assignments don't work with `api_collection`\-based MCP servers.
> - An identity can have only one access assignment per server.
### List MCP access assignments
Returns a paginated list of MCP server access assignments for users or user groups.
**Required privilege:** `mcp_access_assignments.index`.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/access_assignments
</api-code>
#### URL parameters
#### Query parameters
| identity\_type | **string** _required_ | Identity type. Accepted values: `user`, `user_group`. |
| search | **string** _optional_ | Search identity names. |
| order | **string** _optional_ | Sort by identity name. Accepted values: `asc`, `desc`. Defaults to `asc`. |
| page | **integer** _optional_ | Positive page number. Defaults to `1`. |
| per\_page | **integer** _optional_ | Number of items per page, from `1` to `100`. Defaults to `100`. |
#### Sample request
<api-code>
```shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/mcps-7Hk9pQ2r-aB3-1a/access_assignments?identity_type=user_group&page=1&per_page=100' \
</api-code>
Returns `200 OK`.
```json
    "data": [
            "id": "mcpsaa-7Hk9pQ2s-aB3cD4-1a",
            "idp_user_id": null,
            "idp_user_group_id": "group-abc123",
            "all_tools": false,
            "tool_ids": [3001, 3002],
            "created_at": "2026-10-09T10:00:00.000Z",
            "updated_at": "2026-10-09T10:00:00.000Z"
            "id": "mcpsaa-7Hk9pQ2u-jK7mN8-1a",
            "idp_user_group_id": "group-def456",
            "all_tools": true,
            "tool_ids": [],
    "count": 2,
    "page": 1,
    "per_page": 100
The example lists group assignments. Set `identity_type` to `user` to include an `idp_user_id` string and a null `idp_user_group_id` for the assignment. Both identity fields are included by default.
### Create an MCP access assignment
Creates one access assignment for a user or user group on an MCP server.
**Required privilege:** `mcp_access_assignments.create`.
POST https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/access_assignments
</api-code>
#### URL parameters
#### Payload
| idp\_user\_id | **string** _conditional_ | Non-empty identity provider user ID. Supply exactly one of `idp_user_id` or `idp_user_group_id`. |
| idp\_user\_group\_id | **string** _conditional_ | Non-empty identity provider user group ID. Supply exactly one of `idp_user_id` or `idp_user_group_id`. |
| all\_tools | **boolean** _optional_ | Grant access to all tools on the server. Defaults to `false`. |
| tool\_ids | **array of integers** _conditional_ | Required and non-empty when `all_tools` is `false` or omitted. When `all_tools` is `true`, omit this field or send an empty array. Every ID must belong to this server. Use the [List tools](#list-tools-for-an-mcp-server) endpoint to retrieve tool IDs. |
- The identity must be available in the target environment.
- An identity can have only one assignment per server.
- Tool IDs refer to the server's MCP tool records, not recipe IDs or API endpoint IDs.
#### Sample request
<api-code>
```shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/mcps-7Hk9pQ2r-aB3-1a/access_assignments' \
      -d '{
            "all_tools": false,
</api-code>
Use the following request body to grant a user access to all tools:
```json
    "idp_user_id": "user-abc123",
    "all_tools": true
Returns `201 Created`.
```json
    "data": {
        "all_tools": false,
The server generates the assignment ID. Tool IDs are deduplicated and sorted.
### Get an MCP access assignment
Retrieves an access assignment belonging to an MCP server.
**Required privilege:** `mcp_access_assignments.show`.
GET https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/access_assignments/:id
</api-code>
#### URL parameters
| id | **string** _required_ | Access assignment ID belonging to this server. |
This endpoint doesn't accept query or body parameters.
#### Sample request
<api-code>
```shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/mcps-7Hk9pQ2r-aB3-1a/access_assignments/mcpsaa-7Hk9pQ2s-aB3cD4-1a' \
</api-code>
Returns `200 OK`.
```json
    "data": {
        "all_tools": false,
User assignments have both the `idp_user_id` field with the user ID and the `idp_user_group_id` field with a `null` value by default. Assignments that grant all tools have `all_tools: true` and `tool_ids: []`.
### Update an MCP access assignment
Replaces the tool access scope of an existing MCP server access assignment.
**Required privilege:** `mcp_access_assignments.update`.
PUT https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/access_assignments/:id
</api-code>
This path also accepts `PATCH` with the same replacement behavior.
#### URL parameters
#### Payload
| all\_tools | **boolean** _optional_ | Grant access to all tools on the server. Defaults to `false` when omitted. |
| tool\_ids | **array of integers** _conditional_ | Required and non-empty when `all_tools` is `false` or omitted. When `all_tools` is `true`, omit this field or send an empty array. Every ID must belong to this server. |
> **UPDATES REPLACE THE ENTIRE TOOL SCOPE**
> Provide at least one of `all_tools` or `tool_ids`. Omitted fields aren't retained. An omitted `all_tools` defaults to `false`, and an omitted `tool_ids` defaults to an empty array. You can't change the identity on an existing assignment.
#### Sample request
<api-code>
```shell
curl  -X PUT 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/mcps-7Hk9pQ2r-aB3-1a/access_assignments/mcpsaa-7Hk9pQ2s-aB3cD4-1a' \
      -d '{
            "all_tools": false,
            "tool_ids": [3001]
</api-code>
To grant all tools, send `{"all_tools": true}`. The response then contains `all_tools: true` and `tool_ids: []`.
Returns `200 OK`.
```json
    "data": {
        "all_tools": false,
        "tool_ids": [3001],
        "updated_at": "2026-10-09T11:00:00.000Z"
The assignment identity and creation timestamp don't change.
### Delete an MCP access assignment
Deletes a user's or user group's access assignment from an MCP server.
**Required privilege:** `mcp_access_assignments.destroy`.
DELETE https://YOUR_DATA_CENTER/api/mcp/mcp_servers/:mcp_server_handle/access_assignments/:id
</api-code>
#### URL parameters
#### Sample request
<api-code>
```shell
curl  -X DELETE 'https://YOUR_DATA_CENTER/api/mcp/mcp_servers/mcps-7Hk9pQ2r-aB3-1a/access_assignments/mcpsaa-7Hk9pQ2s-aB3cD4-1a' \
</api-code>
Returns `204 No Content` on success, with an empty response body.
