# Audit Log Streaming
Workato can store the job history of all your recipes as well as login and user activity to an Amazon S3 bucket or any REST endpoint. Any log service provider (such as Sumo Logic (opens new window), Datadog (opens new window)) may be used. When enabled, we will create a JSON file for each event. The file size varies from 1 kB to 1 MB based on the details that are present in the logs.
This is an add-on feature. Please view our Pricing page or speak with your account representative to enable audit log streaming in your account.
# How to set up
Click on the Audit log streaming tab in your Account Settings and use the toggle button to enable audit log streaming.
You will then be able to select the type of events that must be included in your audit log stream. You may stream the following information by selecting one or more options. If you choose to stream your job history, you will have the additional option to include your recipe step details in your audit log stream.
# Audit stream destination
You may choose one of the following options as your audit stream destination.
# Amazon S3 bucket
Select an Amazon S3 connection that has a region and bucket set up. The connection should have read/write access to the bucket.
# Azure Blob storage
Select an Azure Blob connection that has containers set up. The connection should have read/write access to the containers. Read here (opens new window) to change role access of the Integration System User (ISU) in your Azure Active Directory. Additional fees (opens new window) are charged by Azure for each 10,000 logs streamed to Azure Blob.
# Azure Monitor
Select an Azure Monitor connection that is tied to a log analytics workspace on your Azure tenant. Head over to the connection docs to learn more.
# Cloud based logging service
Any log service provider (such as Sumo Logic, Datadog, Splunk) may be used. Learn more about configuring an HTTP based log collection using Sumo logic (opens new window) or Datadog (opens new window).
# Requires authentication
If the log service provider requires authentication to send HTTP requests then enable the REQUIRES AUTHENTICATION
toggle.
# HTTP authentication
Select the authentication type in the HTTP connection. Provide authentication details based on the authentication type selected.
# HTTP connection
Link an HTTP connection by creating or linking to an existing HTTP connection. Authentication information must be provided in the HTTP connection.
# HTTP URL
Enter the HTTP URL from the cloud based logging service provider. Workato audit log streaming will POST the audit log events in real-time to this URL.
# Customize log message
Workato lets you customize the audit log message before it is streamed to your choice of security and event management applications like S3, Splunk, Datadog and more. Often times, you may need to send it in a certain format or customize the event message to suit your needs. For example, you may need to include source application (for example, Workato
), environment metadata (like staging or production) so that the event log are automatically processed in the destination application.
In the Account Settings > Audit log streaming > Customize log message
you can create the custom log message using JSON format. Along with your custom fields, define the JSON structure with a placeholder for the Workato audit log that gets replaced with the actual log message before the event is streamed.
Let's see it in action by way of an example. In here, we are sending the source
, environment
and service
fields so that the message gets automatically routed and stored in the right bucket in Datadog.
The {{log_message}}
is the placeholder that Workato uses to substitute the actual audit log event message in JSON format.
"source": "workato",
"environment": "staging",
"hostname": "workato_cloud",
"service": "emp_onboarding",
"logEntries": {{log_message}}
Ensure you define a valid JSON. If the JSON is invalid or does not contain the
{{log_message}}
placeholder, then Workato will send the default log message without any customization.
The log message looks like following in the Datadog
log explorer.
# Custom audit log message fields
# Custom recipe started activity audit log message
# Custom job history audit log message
# JSON file details
Workato creates a JSON file for each event. The file path and name format are as follows:
Item | Description |
path | user_id/jobs/recipe_id/YYYYMMDD/job_id/ Eg: 1234/jobs/456/20220614/j-KGAKfhsz-GYoLeD/ |
name | user_id-recipe_id-job_id-YYYYMMDDHHMMSS-status.json Eg: 1234-456-j-KGAKfhsz-GYoLeD-20220614-succeeded.json |
Example file name: 1234/jobs/456/20220614/j-KGAKfhsz-GYoLeD/1234-456-j-KGAKfhsz-GYoLeD-20220614-succeeded.json
# JSON file content - Job history and step details sample data
Job history - Success
"completed_at": "2020-06-29T11:59:52-07:00",
"is_poll_error": false,
"flow_id": 1207865,
"context": {
"recipe_path": "Home/Audit Log Streaming",
"user_email": "lisa.williams@workato.com",
"recipe_id": 1207865,
"job_created_at": "2020-06-29T11:59:52.004449-07:00",
"user_id": 90125,
"user_name": "Lisa Williams",
"job_id": "j-KGAKfhsz-GYoLeD",
"recipe_name": "New/updated row in a sheet in Google Sheets will log message to output",
"repeated_job": false,
"job_url": "https://www.workato.com/recipes/1207865/job/2162900673",
"recipe_url": "https://www.workato.com/recipes/1207865"
"started_at": "2020-06-29T11:59:52-07:00",
"id": 2162900673,
"action_count": 1,
"lines": [
"output": {
"columns": {
"col_1": "3"
"name": "Test Trigger",
"spreadsheet_id": "1mc_2nMclW3xEn5DvyUSPaNhR-FqioGWtaVDnXxYhvAw",
"row": 4,
"id": "4",
"sheet_name": "Sheet1",
"updated": false
"input": {
"watchfield": "1",
"spreadsheet": "1mc_2nMclW3xEn5DvyUSPaNhR-FqioGWtaVDnXxYhvAw",
"sheet": "Sheet1"
"adapter_name": "google_sheets",
"recipe_line_number": 0,
"adapter_operation": "updated_spreadsheet_row_v4",
"mask_data": false
"output": {
"message": "Current count is 3"
"input": {
"adapter_name": "logger",
"recipe_line_number": 1,
"adapter_operation": "log_message",
"mask_data": false
"status": "succeeded",
"title": "Google Sheets: new/updated row in sheet in my drive: Spreadsheet ID=1mc_2nMclW3xEn5DvyUSPaNhR-FqioGWtaVDnXxYhvAw, Spreadsheet name=Test Trigger, and Sheet name=Sheet1"
Job history - Failure
"completed_at": "2020-06-29T12:12:29-07:00",
"flow_id": 29220,
"error_type": "Exception",
"context": {
"recipe_path": "Home",
"user_email": "david.smith@workato.com",
"recipe_id": 29220,
"job_created_at": "2020-06-29T12:12:28.733533-07:00",
"user_id": 4805,
"user_name": "David Smith",
"recipe_name": "Update incident in ServiceNow",
"job_url": "https://www.workato.com/recipes/29220/job/2200127784",
"recipe_url": "https://www.workato.com/recipes/29220"
"started_at": "2020-06-29T12:12:28-07:00",
"id": "j-KGAKfhsz-GYoLeD",
"action_count": 1,
"error": "{\"message\":\"404 Not Found\",\"inner_message\":\"#\\u003cRestClient::NotFound: 404 Not Found\\u003e\"}",
"lines": [
"output": {
"time": "2020-06-29T12:12:27.765777-07:00"
"input": {
"interval": "60"
"adapter_name": "clock",
"adapter_operation": "timer",
"mask_data": false
"input": {
"sys_id": "107813476",
"row": {
"caller_id": "0878",
"category": "245"
"table": "incident~Incident"
"adapter_name": "service_now",
"adapter_operation": "update_object",
"error": "404 Not Found",
"mask_data": false
"status": "failed",
"title": "Scheduler by Workato: new scheduled event: Start time=2020-06-29T12:12:27.765777-07:00"
# JSON file content - Login and user activity
User login
"resource": {
"email_confirmed_at": "2019-11-24 14:29:30 -0800",
"name": "John Smith",
"id": 4848,
"type": "User",
"email": "john.smith@workato.com"
"details": {
"request": {
"ip_address": "60.160.90.91",
"user_agent": "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_3) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.113 Safari/537.36"
"activity": "sso_login",
"sso_provider": "google"
"team": {
"name": "Workato Team",
"id": 4848,
"event": "user_login",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:39:22 UTC"
User logout
"resource": {
"id": 4848,
"type": "User",
"details": {
"request": {
"activity": "user_logout"
"team": {
"id": 4848,
"event": "user_logout",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:39:10 UTC"
Manifest updated
"resource": {
"name": "Document reading",
"id": 911,
"type": "ExportManifest"
"details": {
"request": {
"team": {
"name": "Workato eam",
"id": 4848,
"event": "manifest_updated",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:51:46 UTC"
Package exported
"resource": {
"file_name": "vision-ai-license-and-registration_john-smith.zip",
"id": 1076,
"type": "Package",
"folder_id": 5223,
"folder_path": "Home/Vision AI - License and Registration"
"team": {
"id": 4805,
"event": "package_exported",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:52:17 UTC"
Package imported
"resource": {
"file_name": "griddynamics_demo.zip",
"id": 1077,
"type": "Package",
"folder_id": 6593,
"folder_path": "Home/HR"
"team": {
"id": 4848,
"email": "johm.smith@workato.com"
"event": "package_imported",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:53:33 UTC"
Recipe created
"resource": {
"name": "Candidate in Progress on JIRA will advance on GreenHouse",
"id": 33167,
"type": "Flow"
"team": {
"name": "Workato team",
"id": 4848,
"event": "recipe_created",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:53:32 UTC"
Recipe updated
"resource": {
"name": "Trigger on a specified interval will send request via HTTP",
"id": 32896,
"type": "Flow"
"details": {
"request": {
"team": {
"id": 4848,
"event": "recipe_updated",
"user": {
"name": "john.smith",
"id": 4848,
"timestamp": "2020-05-04 18:26:28 UTC"
Recipe deleted
"resource": {
"parent_id": 32896,
"name": "Send opportunity sync request via HTTP",
"id": 33179,
"type": "Flow"
"details": {
"request": {
"team": {
"id": 4848,
"event": "recipe_deleted",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:39:15 UTC"
Recipe cloned
"resource": {
"id": 32896,
"type": "Flow"
"details": {
"request": {
"team": {
"id": 4848,
"event": "recipe_copied",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:32:43 UTC"
Recipe renamed
"resource_changes": {
"name": {
"old_value": "Send request via HTTP"
"resource": {
"parent_id": 32896,
"id": 33179,
"type": "Flow"
"details": {
"request": {
"team": {
"id": 4848,
"event": "recipe_renamed",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:33:23 UTC"
Recipe started
"resource": {
"parent_id": 32896,
"id": 33179,
"type": "Flow"
"details": {
"request": {
"ip_address": "67.164.97.88",
"run_once": false
"team": {
"id": 4848,
"event": "recipe_started",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:38:46 UTC"
Recipe stopped
"resource": {
"parent_id": 32896,
"id": 33179,
"type": "Flow"
"details": {
"request": {
"stop_reason": "user",
"force": false,
"error": false
"team": {
"id": 4848,
"event": "recipe_stopped",
"user": {
"name": "Johm Smith",
"id": 4848,
"timestamp": "2020-05-04 18:39:06 UTC"
Folder created
"resource": {
"path": "Home/RevOps Salesforce <> Netsuite",
"name": "RevOps Salesforce <> Netsuite",
"id": 6847,
"type": "Folder"
"details": {
"request": {
"team": {
"id": 4848,
"event": "folder_created",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:48:08 UTC"
Folder deleted
"resource": {
"path": "RevOps Salesforce <> Netsuite",
"id": 6847,
"type": "Folder"
"details": {
"request": {
"team": {
"id": 4848,
"event": "folder_deleted",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:50:20 UTC"
Team - Invited a team member
"resource": {
"role": "Admin",
"name": "Alice Jackson",
"id": 847,
"type": "MemberInvitation",
"email": "alice.jackson@workato.com"
"details": {
"request": {
"team": {
"id": 4848,
"event": "team_invitation_created",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:53:59 UTC"
Team - Member accepted invite
"resource": {
"role": "Admin",
"id": 847,
"details": {
"request": {
"user_agent": "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:75.0) Gecko/20100101 Firefox/75.0"
"team": {
"id": 4848,
"event": "team_invitation_accept",
"user": {
"id": 6464,
"timestamp": "2020-05-04 20:05:02 UTC"
Team - Member deleted
"resource": {
"role": "Admin",
"grant_type": "team",
"member": {
"email_confirmed_at": "2019-09-11 14:38:19 -0700",
"name": "Nick Jefferies",
"id": 4941,
"type": "User",
"email": "nick.jefferies@workato.com"
"id": 1483,
"type": "ManagedUserGrant"
"details": {
"request": {
"team": {
"id": 4848,
"event": "team_membership_deleted",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:53:16 UTC"
Team - Switched into a team
"resource": {
"id": 4848,
"type": "User",
"details": {
"request": {
"activity": "switch_team"
"team": {
"id": 4848,
"user": {
"id": 6464,
"timestamp": "2020-05-04 20:27:33 UTC"
Team - Switched out of a team
"resource": {
"id": 4848,
"type": "User",
"details": {
"request": {
"team": {
"id": 4848,
"user": {
"id": 6464,
"timestamp": "2020-05-04 20:28:01 UTC"
Connection - Connected
"resource": {
"provider": "postgresql",
"authorized": true,
"name": "My PostgreSQL account",
"id": 7145,
"type": "SharedAccount"
"details": {
"request": {
"team": {
"id": 4848,
"event": "connection_connected",
"user": {
"id": 4848,
"timestamp": "2020-05-04 20:56:35 UTC"
Connection - Disconnected
"resource": {
"authorized": false,
"id": 7145,
"details": {
"request": {
"team": {
"id": 4848,
"event": "connection_disconnected",
"user": {
"id": 4848,
"timestamp": "2020-05-04 20:56:24 UTC"
Connection - Created
"resource": {
"provider": "asana",
"name": "My second Asana account",
"id": 7174,
"details": {
"request": {
"team": {
"id": 4848,
"event": "connection_created",
"user": {
"id": 4848,
"timestamp": "2020-05-04 21:59:58 UTC"
Connection - Updated
"resource": {
"id": 7145,
"details": {
"request": {
"team": {
"id": 4848,
"event": "connection_updated",
"user": {
"id": 4848,
"timestamp": "2020-05-04 20:56:32 UTC"
Connection - Deleted
"resource": {
"provider": "greenhouse_connector_4805_1566279565",
"name": "Carly's Greenhouse Account",
"id": 6588,
"details": {
"request": {
"team": {
"id": 4848,
"event": "connection_deleted",
"user": {
"id": 4848,
"timestamp": "2020-05-04 20:57:21 UTC"
Connector - Updated
"resource": {
"name": "Greenhouse",
"id": 1884,
"type": "Adapter"
"team": {
"id": 4848,
"event": "connector_updated",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:53:28 UTC"
