Workato CLI example use cases
The following example use cases describe how you can use the Workato Platform CLI for individual developer, team and organization, automation, and enterprise integration workflows.
Individual developer example use cases
You can use the Platform CLI for individual developer use cases, such as local recipe development and multi-environment management.
Local recipe development
Edit and validate integration recipes locally before deployment to avoid production issues.
Benefits
  • Catch syntax errors early
  • Version control integration recipes
  • Test recipes using different profiles for development, staging, and production
  • Faster development cycles
Commands
bash
workato recipes validate --path ./recipes/RECIPE-NAME.json
workato push --restart-recipes
Example
bash
% workato recipe validate --path ./customer_onboarding/google_calendar_recipe.recipe.json
 Recipe validation passed (0.1s)
📄 File: google_calendar_recipe.recipe.json
% workato push --restart-recipes
 Package created: customer_onboarding.zip (0.1s)
 Package uploaded successfully (0.9s)
  📊 Import ID: 203018
  📈 Status: in_progress
🎉 Import completed successfully
📋 Recipe Import Results:
 4 recipe(s): No restart needed
  ⚠️ 1 recipe(s): Updated but stopped
  📊 Summary: 4/5 recipes imported successfully
Multi-environment management
Manage development, staging, and production environments with separate configurations.
Benefits
  • Isolated testing environments
  • Safer promotion workflows
  • Environment-specific configurations
  • Rollback capabilities
Workflow
bash
# Development
workato profiles use dev
workato push
# Staging
workato profiles use staging
workato pull
# Production
workato profiles use production
workato pull
Example
bash
# Development
% workato profiles use dev
 Set 'dev' as profile for current workspace
   Workspace: /Users/user-directory/workato
   Project config also updated: customer_onboarding
% workato push
  📊 Import ID: 203022
 5 recipe(s): No restart needed
# Staging
% workato profiles use staging
 Set 'staging' as profile for current workspace
% workato pull
Pulling latest changes for project: customer_onboarding
 Export manifest created: 39763 (0.9s)
 Export package triggered: 203024 (0.5s)
 Package ready for download (2.4s)
 Package downloaded (0.4s)
 Project assets extracted (0.1s)
 Project is already up to date
 Package uploaded successfully (0.8s)
  📊 Import ID: 203025
# Production
% workato profiles use production
 Set 'production' as profile for current workspace
% workato pull
 Export manifest created: 39765 (0.8s)
 Export package triggered: 203028 (0.4s)
 Package ready for download (2.5s)
 Package downloaded (0.7s)
Team and organization example use cases
You can use the Platform CLI for team and organization use cases, such as collaboration, CI/CD pipeline integration, and recipe lifecycle management.
Team collaboration
Share recipes and connections across development teams with standardized workflows.
Benefits
  • Consistent project structures
  • Shared connection configurations
  • Code review processes for integrations
  • Knowledge sharing
Workflow
bash
# Developer A
workato push --include-tags
# Developer B
workato pull
Example
bash
# Developer A
% workato push --include-tags
  📊 Import ID: 203030
# Developer B
% workato pull
 Export manifest created: 39766 (0.5s)
 Export package triggered: 203031 (0.6s)
Automate recipe deployment as part of build and release pipelines.
Benefits
  • Consistent deployment process
  • Automated validation gates
  • Environment promotion workflows
  • Reduced manual errors
Implementation
bash
# In CI pipeline
workato recipes validate --path ./recipes/*.json
workato push --restart-recipes --include-tags
Example
bash
% workato recipes validate --path ./customer_onboarding/google_calendar_recipe.recipe.json
 Recipe validation passed (2.0s)
% workato push --restart-recipes --include-tags
 Package uploaded successfully (1.0s)
  📊 Import ID: 203034
Recipe lifecycle management
Standardize how recipes are created, tested, deployed, and monitored across teams.
Operations
  • Validate recipes before deployment
  • Start/stop recipes for maintenance
  • Monitor recipe execution
  • Update connections programmatically
Commands
bash
workato recipes validate --path ./recipe.json
workato recipes start --id 12345
workato recipes stop --id 67890
workato connections create-oauth --parent-id 123
Automation
You can use the Platform CLI for automated connection management, and error resolution and monitoring.
Automated connection management
You can handle OAuth flows and credential management programmatically.
Benefits
  • Eliminate manual OAuth setup
  • Bulk connection creation
  • Secure credential handling
Commands
bash
workato connections get-oauth-url --id 456
Error resolution and monitoring
You can automatically diagnose and resolve common integration issues.
Benefits
  • Proactive issue detection
  • Automated troubleshooting
  • Performance monitoring
  • Reduced downtime
Monitoring
bash
workato recipes list --running
workato recipes list --stop-cause trigger_errors_limit
Example
bash
% workato recipes list --running
📋 Recipes (1 found) - (0.8s)
  🔍 Filters: folder 75510, running recipes only
  ▶️ Google Calendar Recipe
    🆔 ID: 366663
    📊 Status: Running
    📱 Trigger App: clock
    🔧 Action Apps: google_calendar
    ⚙️  Config Apps: clock, google_calendar (Account: 71959)
    📁 Folder ID: 75510
    📊 Jobs: 24 succeeded, 0 failed
    🕐 Last Run: 2025-10-28T12:49:55.834000-07:00
    📅 Created: 2025-03-25T11:58:33.598000-07:00
    👤 Author: Amy Peak
    📝 Description: When there is a trigger on a specified schedule, do action
% workato recipes list --stop-cause trigger_errors_limit
📋 Recipes (0 found) - (0.4s)
  🔍 Filters: folder 75510, stopped due to: trigger_errors_limit
  ℹ️  No recipes found
  ℹ️  No recipes found
Enterprise integration scenarios
You can use the Platform CLI for enterprise integration scenarios, such as API management, data operations, and project organization.
API management
Centralize API collection management and deployment across multiple environments.
Benefits
  • Consistent API definitions
  • Version control for API specs
  • Automated API deployment
Implementation
bash
workato api-collections create --format yaml --content ./api-spec.yaml --name "API-COLLECTION-NAME"
Data operations
Manage large-scale data synchronization and transformation workflows.
Benefits
  • Batch processing capabilities
  • Data validation and cleansing
  • Error handling and retry logic
  • Audit trails and monitoring
Project organization
You can structure projects for scalability and maintainability across large teams.
Benefits
  • Consistent folder structures
  • Shared naming conventions
  • Access control management
  • Dependency tracking
Organization
  • Group recipes by business function
  • Use descriptive connection names
  • Implement consistent tagging
  • Regular cleanup and maintenance
