# View test case run results
When Workato finishes running a test job, you receive a notification with the test case run results.
The test case run results modal contains the following information about each test case that was executed.
- Recipe name
- Test case name
- Test case run result (passed/failed)
- Check that failed (if any)
- Link to a job for a test case run
# If the test case has no checks
The job run result is the same as the test case run result.
# Test case run jobs
In addition to viewing test case run results after a test case run completes, you can access all test case run results at the recipe level on the Jobs page.
 Select a test case run job from the list
# Test case job metadata
The Jobs page for each test case run contains the following information.
- Steps that were mocked
- Steps that had checks
- For each check
- Check data
- Check result
- For each check
- Test case name and link
- If the test case was deleted, Workato only displays the name of the deleted test.
      FAQs
