# Collaborator Roles And Privileges
Collaborator roles control team access to Workato features, functions, and folders of Role-based access control.
In this guide, we'll cover:
Have Environment Setup?
Find out how Environment works with Team roles.
# System Roles
System roles are pre-defined roles in Workato that can be assigned to team collaborators.
Workato has four system roles: Team owner, Admin, Analyst, and Operator.
# Team owner
The Team Owner role is the most permissive system role. It owns the root login (username/password) for the account and includes full access to all settings for the account.
All Admin role privileges
All privileges included in the Admin role.
Full Account Settings access
Access to all account settings.
# Admin
Typically granted to users managing the Workato team account, Admins have nearly equivalent privileges to the Team Owner. Aside from the Team Owner, this is the most permissive system role.
Full project access
All project permissions: View, edit, create, and delete.
Full folder access
All folder permissions: View, edit, create, and delete.
Full connection access
All connection permissions: View, edit, create, and delete.
Full recipe access
All recipe permissions: View, edit, create, delete, run, and view job history.
Full access network trace
View network traces in job histories. Includes recipe input, output, and the network trace of HTTP calls. HTTP call info includes HTTP headers, requests, and communication (responses) between Workato and the end application.
All projects
Access to all projects in a workspace.
Full access
Access to the API Platform, including collections, client policies, logs, and settings.
Full Common data model access
All Common data model permissions: View, edit, create, and delete.
Full Custom OAuth Profile access
All Custom OAuth Profile permissions: View, edit, create, and delete.
Full Lookup table access
Access to the Lookup tables feature.
Full Message template access
All Message template permissions: View, edit, create, and delete.
Full On-prem groups access
Access all on-prem groups and agents in the workspace.
Full People task access
Access to the People task tool.
Full Properties access
Access to all Account Properties in the workspace.
Full Pub/Sub access
All Pub/Sub permissions: View, edit, create, and delete topics.
Full Recipe lifecycle management access
Access to the Recipe lifecycle management feature.
Full Workbot access
All Workbot permissions: View, edit, create, and delete.
Full Runtime user connection access
All Runtime user connection permissions: View and edit.
Full Logs access
Access to the Workato Log Service feature.
Full Connector SDK access
All Connector SDK permissions: View, edit, create, and delete.
Full Team access
Manage the team in the workspace, including adding, editing, and removing collaborators.
Full Custom team roles access
View, edit, create, and delete custom team roles in the workspace.
Full SAML SSO access
View and edit SAML SSO settings for the workspace.
Full activity audit
Access to view team activity in the Dashboard's Activity audit log. This permission grants the user the ability to view all activity logs, regardless of other access settings.
Full key management
Access to the account's Key Management System (KMS). Users with this privilege can update key policies and encryption keys.
# Analyst
Analysts are typically users who build and test recipes or custom connectors.
Full project access
Full folder access
Full recipe access
All projects
Full access
Full Pub/Sub access
Full Workbot access
# Operator
Operators are users who focus on maintaining and validating existing recipes. This is the least permissive system role.
This role includes read-only access to All folders and All projectsß.
View projects
View specific projects in a workspace.
View folders
View folders and sub-folders in a workspace.
View recipes
View recipes in a workspace.
Test (start/stop) recipes
Run recipes and start and stop recipe tests in a workspace.
View recipe job history
View a recipe's job history in the Jobs tab.
All projects
These roles can't be edited directly but may be cloned and then modified.
To view the privileges of a system role, a Team Admin can select a role in the Roles tab. This will open a read-only version of the role.
# Custom Roles
CUSTOM ROLES IS AN ADD-ON
Custom roles is available as an add-on. Contact your Customer Success Manager for more info.
Workato also supports custom roles, enabling you to assign granular privileges to team collaborators.
For example: Development, QA, and Production teams are working in the same account. As part of the Recipe development lifecycle, you can create and assign roles with specific privileges to each team.
Refer to the Role-based access guide to learn how to create a custom role.
# Privileges
In this section, you'll find info about each of the privileges in Workato.
When you create or modify a role, you'll see the following tabs:
# Recipe Development Privileges
The Recipe development tab controls access and privileges related to projects, recipes, folders, and connections:
# Recipe Creation
Privilege type Privilege levels
Projects
  • Full project access: All project permissions: View, edit, create, and delete.
  • View projects: View specific projects in a workspace.
  • Edit projects: Edit specific projects in a workspace.
  • Create projects: Create projects in a workspace.
  • Delete projects: Delete projects in a workspace.
Folders
  • Full folder access: All folder permissions: View, edit, create, and delete.
  • View folders: View folders and sub-folders in a workspace.
  • Edit folders: Edit folders and sub-folders in a workspace.
  • Create folders: Create folders and sub-folders in a workspace.
  • Delete folders: Delete folders and sub-folders in a workspace.
Connections
  • Full connection access: All connection permissions: View, edit, create, and delete.
  • View connections: View connections in a workspace.
  • Edit connections: Edit connections in a workspace.
  • Create connections: Create connections in a workspace.
  • Delete connections: Delete connections in a workspace.
Recipes
  • Full recipe access: All recipe permissions: View, edit, create, delete, run, and view job history.
  • View recipes: View recipes in a workspace.
  • Edit recipes: Edit recipes in a workspace.
  • Create recipes: Create recipes in a workspace.
  • Delete recipes: Delete recipes in a workspace.
  • Test (start/stop) recipes: Run recipes and start and stop recipe tests in a workspace.
  • View recipe job history: View a recipe's job history in the Jobs tab.
Back to Recipe development | Back to Privileges
# Debug Jobs
Network trace
  • Full access network trace: View network traces in job histories.
# Project Access
Project access
  • All projects: Access to all projects in a workspace.
  • Selected projects: Access to specific projects in a workspace. If this option is selected, the user will only have access to the projects specified here.
# Platform Tools Privileges
# Tools
API platform
  • Full access: Access to the API Platform, including collections, client policies, logs, and settings.
Common data models
  • Full Common data model access: All Common data model permissions: View, edit, create, and delete.
  • View Common data models: View Common data models in the workspace.
  • Edit Common data models: Edit Common data models in the workspace.
  • Create Common data models: Create Common data models in the workspace.
  • Delete Common data models: Delete Common data models in the workspace.
Custom OAuth profiles
  • Full Custom OAuth Profile access: All Custom OAuth Profile permissions: View, edit, create, and delete.
  • View Custom OAuth Profiles: View Custom OAuth Profiles and Enterprise Workbots.
  • Edit Custom OAuth Profiles: Edit Custom OAuth Profiles and Enterprise Workbots.
  • Create Custom OAuth Profiles: Create Custom OAuth Profiles and Enterprise Workbots.
  • Delete Custom OAuth Profiles: Delete Custom OAuth Profiles and Enterprise Workbots.
Lookup tables
Message templates
  • Full Message template access: All Message template permissions: View, edit, create, and delete.
  • View Message templates: View Message templates in the workspace.
  • Edit Message templates: Edit Message templates in the workspace.
  • Create Message templates: Create Message templates in the workspace.
  • Delete Message templates: Delete Message templates in the workspace.
On-prem groups
People tasks
Properties
PubSub
  • Full PubSub access: All PubSub permissions: View, edit, create, and delete topics.
  • View PubSub topics: View PubSub topics in the workspace.
  • Edit PubSub topics: Edit PubSub topics in the workspace.
  • Create PubSub topics: Create PubSub topics in the workspace.
  • Delete PubSub topics: Delete PubSub topics in the workspace.
Workbot
  • Full Workbot access: All Workbot permissions: View, edit, create, and delete.
  • View Workbots: View installed Workbots in the workspace.
  • Edit Workbots: Edit installed Workbots in the workspace.
  • Create Workbots: Create Workbots in the workspace.
  • Delete Workbots: Delete installed Workbots in the workspace.
Runtime user connections
  • Full Runtime user connection access: All Runtime user connection permissions: View and edit.
  • View Runtime user connections: View the Runtime user connections setting.
  • Edit Runtime user connections: Edit the Runtime user connections setting.
Workato log service
Back to Platform tools | Back to Privileges
# Connector SDK
Connector SDK
  • Full Connector SDK access: All Connector SDK permissions: View, edit, create, and delete.
  • View SDK connectors: View SDK connectors.
  • Edit SDK connectors: Edit SDK connectors.
  • Create SDK connectors: Create SDK connectors.
  • Delete SDK connectors: Delete SDK connectors.
# Admin Privileges
Team
Custom team roles
  • Full Custom team roles access: View, edit, create, and delete custom team roles in the workspace.
SAML SSO
Activity audit
  • Full activity audit: Access to view team activity in the Dashboard's Activity audit log. Note: This permission grants the user the ability to view all activity logs, regardless of other access settings.
Key management
  • Full key management: Access to the account's Key Management System (KMS). Users with this privilege can update key policies and encryption keys.
Back to Privileges
