Managed Users
Use the following endpoints to manage OEM users.
Supported Formats
  • Json
Create new OEM users
POST /api/managed_users
Description
Creates a new OEM user. Requires 'oem_vendor' privilege.
  • The new account is assigned the plan specified in the master account's OEM configuration.
  • Configures preferred authentication mode for the child account based on the value specified in the master account's OEM configuration.
  • Sets the plan of the new account based on the OEM configuration.
Details
Parameters
Parameter name Description
name
required
Full name of the user
Validations:
  • Must be string
oauth_id
required
Identifier used for OAuth
Validations:
  • Must be string
notification_email
required
Email for error notifications
Validations:
  • Must be string
external_id
optional
External identifier for the user
Validations:
  • Must be string
Example
  "name": "Kevin O'Leary",
  "oauth_id": "AAA0932808240:UU0239093498",
  "notification_email": "kevinl@acme.com",
  "external_id": "UU0239093498"
Responses
Code Description
200 Success
400 Bad request
401 Unauthorized
500 Server error
Examples
Success: 200
  "id": 3498583,
  "plan_id": "oem_plan",
  "trial": false
Server error: 500
  "message":"Server error",
  "id": "32y2298sjbjdwejweg"
Add member to OEM account
POST /api/managed_users/:id/member
Description
Adds a member to the OEM account. Requires 'oem_vendor' privilege.
  • Creates a new Workato member account and makes the user member of the given team.
  • Configures preferred authentication mode for the member based on the value specified in the master account's OEM configuration.
Details
Parameters
name
required
Validations:
  • Must be string
oauth_id
required
Validations:
  • Must be string
role_name
optional
Membership role name
Validations:
  • Must be string
external_id
optional
Validations:
  • Must be string
Example
  "name": "Jack Smith",
  "oauth_id": "AAA0932808240:UU0239093499",
  "role_name": "Admin",
  "external_id": "UU0239093499"
Responses
Code Description
200 Success
400 Bad request
401 Unauthorized
404 Not found
500 Server error
Examples
Success: 200
POST /api/managed_users/12/member
  "id": 3498583,
  "trial": false
Server error: 500
results matching ""
    No results matching ""
