Project grants
Use the following endpoints to manage a collaborator or group's project grants.
API CLIENT ACCESS
Project grant endpoints can only assign project roles to environments and projects that the API client can access. For example, an API client assigned to the TEST environment can only manage TEST projects. Additionally, if an API client is assigned to specific projects, it can only manage those projects. Refer to Create a client role to configure an API client's access.
Rate limits
The project grants resource has the following rate limit:
TypeResourceLimit
All All Project grants endpoints60 requests per minute
What are project grants?
A project grant assigns a project role to a collaborator or group. Refer to Manage project access and roles to manage assigned project roles in the UI.
Quick reference
TypeResourceDescription
GET/api/project_grants/:idGet a project grant.
PUT/api/project_grants/:idUpdate a project grant.
DELETE/api/project_grants/:idDelete a project grant.
GET/api/projects/:id/project_grantsList project grants by project ID.
PUT/api/projects/:id/project_grantsAdd or update project grants.
Get a project grant
Retrieves a project grant by its ID.
shell
GET /api/project_grants/:id
Path parameters
NameTypeDescription
idstring
required
The ID of the project grant to retrieve.
Sample request
shell
curl -X GET 'https://www.workato.com/api/project_grants/pg-AQAEnmKC-Dtt9aD' \
Response
json
  "data" : {
    "id": "pg-AQAEnmKC-Dtt9aD",
    "project": {
      "id": 178229,
      "name": "Development",
      "environment": {
        "id": 148425,
        "type": "dev"
    "project_role": {
      "id": "pr-AQBGCnMB-JoFtKL",
      "name": "Developers"
    "user_group": null,
    "user": {
      "id": 1,
      "name" : "Taylor",
      "email": "[email protected]"
Updates an existing project grant by its ID.
shell
PUT /api/project_grants/:id
Path parameters
NameTypeDescription
idstring
required
The ID of the project grant to update.
Request body
NameTypeDescription
project_grantobject
required
Defines the updated project grant.
project_grant[project_role_id]string
required
The ID of the project role to assign.
Sample request
shell
curl -X PUT 'https://www.workato.com/api/project_grants/pg-AQAEnmKC-Dtt9aD' \
  -d '{
        "project_grant": {
          "project_role_id": "pr-AQBGCnMB-JoFtKL"
Response
json
  "data" : {
    "project": {
      "id": 178229,
      "environment": {
        "id": 148425,
        "type": "dev"
    "project_role": {
    "user_group": {
      "id": "am-WxEKCibh-dTXBtz",
      "name" : "Developers",
      "system": false
    "user": null
400 BAD REQUEST
A 400 Bad Request error indicates that the server couldn't process the request due to client-side issues. Common causes include malformed requests, invalid fields, or violations of field constraints, such as unsupported data types.
In the following example, the request fails because the assignment is already taken:
json
  "errors": [
      "code": "bad_request",
      "title": "Assignment has already been taken"
Deletes a project grant by its ID.
shell
DELETE /api/project_grants/:id
Path parameters
NameTypeDescription
idstring
required
The ID of the project grant to delete.
Sample request
shell
curl -X DELETE 'https://www.workato.com/api/project_grants/pg-AQAEnmKC-Dtt9aD' \
Response
A successful request returns a 204 No Content status code. The API deletes the project grant and returns an empty response body.
List project grants
Retrieves a list of grants from a project by its ID.
shell
GET /api/projects/:id/project_grants
Path parameters
NameTypeDescription
idstring
required
The ID of the project to retrieve grants from.
Query parameters
NameTypeDescription
page[number]integer
optional
The page number to retrieve. The default value is 1.
page[size]integer
optional
The number of items per page to retrieve. The default and maximum value is 100.
Sample request
shell
curl -X GET 'https://www.workato.com/api/projects/178229/project_grants?page[number]=1&page[size]=100' \
Response
json
  "data": [
      "id": "pg-AQAEnmMX-b4rPeT",
      "project_role": {
        "id": "pr-AQAEnmK3-EQpeYM",
      "user": {
        "id": 1,
        "name" : "Jie",
      "user_group": null
      "project_role": {
      "user": null,
      "user_group": {
        "system": false
  "total": 2,
  "page": {
    "number": 1,
    "size": 100
Adds or updates project grants for a project by its ID. You can include a maximum of 100 grants in each request.
shell
PUT /api/projects/:id/project_grants
Path parameters
NameTypeDescription
idstring
required
The ID of the project where you plan to add or update grants.
Request body
NameTypeDescription
project_grantsobject
required
Defines project grants for the project.
project_grants[assignment_type]string
required
Specifies whether to assign the role to a workspace (User) or collaborator group (UserGroup).
project_grants[assignment_id]string
required
The ID of the target workspace or collaborator group.
project_grants[project_role_id]string
required
The ID of the role to assign.
Sample request
shell
curl -X PUT 'https://www.workato.com/api/projects/178229/project_grants' \
  -d '{
        "project_grants": [
            "assignment_type": "User",
            "assignment_id": "1",
            "project_role_id": "pr-AQAEnmK3-EQpeYM"
            "assignment_type": "UserGroup",
            "assignment_id": "am-WxEKCibh-dTXBtz",
Response
A successful request returns { "data": null }. This response indicates the operation succeeded, but no additional data is returned.
400 BAD REQUEST
In the following example, the request fails because it exceeds the maximum number of grants per request:
json
  "errors": [
      "title": "Max 100 project grants per request"
