Workato Identity IAM
The Workato Identity APIs allow you to programmatically manage user identities, group memberships, and access control.
Rate limits
Workato Identity IAM resources have the following rate limits:
| Type | Resource | Limit |
| All | All Workato Identity IAM endpoints | 60 requests per minute |
Quick reference
| GET | /api/iam/users | List users in the workspace. |
| GET | /api/iam/users/:user-id | Retrieve details for a specific user by ID. |
| POST | /api/iam/users | Create one or more new users. |
| PUT | /api/iam/users/:user-id | Update an existing user. |
| DELETE | /api/iam/users/:user-id | Delete a user from the workspace. |
| POST | /api/iam/users/:user-id/add_to_group | Add a user to a specific group. |
| POST | /api/iam/users/:user-id/remove_from_group | Remove a user from a specific group. |
| GET | /api/iam/user_groups | List user groups in the current environment. |
| GET | /api/iam/user_groups/:user-group-id | Retrieve details for a specific user group by ID. |
| POST | /api/iam/user_groups | Create a new user group. |
| PUT | /api/iam/user_groups/:user-group-id | Update an existing user group. |
| DELETE | /api/iam/user_groups/:user-group-id | Delete a user group. |
| POST | /api/iam/user_groups/:user-group-id/add_users | Add multiple users to a group. |
| DELETE | /api/iam/user_groups/:user-group-id/remove_users | Remove multiple users from a group. |
| GET | /api/iam/user_groups/:user-group-id/members | List all members of a user group. |
| GET | /api/iam/app_links | List app links in the current environment. |
| POST | /api/iam/app_links | Create an app link. |
| DELETE | /api/iam/app_links/:id | Delete an app link by ID. |
| DELETE | /api/iam/app_links | Delete app links by IDs. |
Users
The following endpoints enable you to manage Workato Identity users:
List users
List all users in your workspace.
GET /api/iam/usersQuery parameters
| Name | Type | Description |
| query | string optional | Search query to filter users. |
| emails[] | array[string] optional | Filter by email addresses. |
| user_ids[] | array[string] optional | Filter by user IDs. |
| name | string optional | Filter by user name. |
| user_group_ids[] | array[string] optional | Filter by user group IDs. |
| environment_id | string optional | Filter group membership by environment ID. |
| order_by | string optional | Sort by name, email, or status. |
| order | string optional | Sort direction: asc or desc. |
| page | integer optional | Page number. Defaults to 1. |
| per_page | integer optional | Page size. Max/default is 100. |
Sample request
curl -X GET 'https://www.workato.com/api/iam/users?page=1&per_page=100' \
-H 'Content-Type: application/json'Response
"data": [
"id": "user-id",
"email": "[email protected]",
"name": "Jade Anderson",
"status": "active",
"last_signed_in_at": "2025-01-15T10:30:00Z",
"created_at": "2025-01-01T00:00:00Z",
"environment_ids": ["env-id"],
"user_groups": [
"id": "user-group-id",
"environment_id": "env-id",
"name": "Developers"
"total": 1,
"page": {
"number": 1,
"size": 100
}Get user by ID
GET /api/iam/users/:user-idURL parameters
| user-id | string required | User ID. |
Sample request
curl -X GET 'https://www.workato.com/api/iam/users/:user-id' \
"data": {
"id": "user-id",
"status": "active",
"user_groups": [
}Create user
Create one or more new users in your workspace.
POST /api/iam/usersPayload
| users[] | array required | Array of user objects to create. |
| users[].email | string optional | User email address. |
| users[].name | string optional | User display name. |
| users[].user_group_ids[] | array[string] optional | Group IDs. You must provide environment_types[] if you provide Group IDs. |
| users[].environment_types[] | array[string] optional | Environment types. For example: dev, test, or prod. |
Sample request
curl -X POST https://www.workato.com/api/iam/users \
-d '{
"users": [
"user_group_ids": ["user-group-id"],
"environment_types": ["dev"]
}'Response
"data": {
"id": "new-user-id"
}Update user
Update an existing user's information, including name and group memberships.
PUT /api/iam/users/:user-idURL parameters
Payload
| name | string optional | Updated user name. |
| user_group_ids[] | array[string] optional | Updated list of group IDs. |
| environment_types[] | array[string] optional | Environment types (dev, test, prod). |
| environment_user_groups[] | array[object] optional | Explicit environment group assignments with id and environment_id. |
Sample request
curl -X PUT https://www.workato.com/api/iam/users/:user-id \
-d '{
"name": "Developer CI/CD",
"environment_types": ["dev", "test"],
"environment_user_groups": [
{"id": "user-group-id", "environment_id": "env-id"}
}'Response
"data": {
"id": "user-id",
"status": "active",
"environment_ids": ["env-id", "env-id-2"],
"user_groups": [
}Delete user
Delete a user from your workspace.
PERMANENT ACTION
This action permanently removes the user from your workspace. This action doesn't delete the user from the system.
DELETE /api/iam/users/:user-idURL parameters
Sample request
curl -X DELETE 'https://www.workato.com/api/iam/users/:user-id' \
-H 'Authorization: Bearer <api_token>'Response
"data": null
}Add user to group
Add a user to a specific user group.
POST /api/iam/users/:user-id/add_to_groupURL parameters
Payload
| user_group_id | string required | User group ID. |
Sample request
curl -X POST https://www.workato.com/api/iam/users/:user-id/add_to_group \
-d '{
"user_group_id": "user_group_id"
}'Response
"data": {
"id": "user-id",
"status": "active",
"user_groups": [
}Remove user from group
Remove a user from a specific user group.
POST /api/iam/users/:user-id/remove_from_groupURL parameters
Payload
Sample request
curl -X POST https://www.workato.com/api/iam/users/:user-id/remove_from_group \
-d '{
}'Response
"data": {
"id": "user-id",
"status": "active",
"user_groups": []
}User Groups
The following endpoints enable you to manage Workato Identity groups:
List user groups
List all user groups in the current environment.
GET /api/iam/user_groupsQuery parameters
| query | string optional | Search query to filter user groups. |
| order_by | string optional | Field to order results by. Allowed: name. |
Sample request
curl -X GET 'https://www.workato.com/api/iam/user_groups?page=1&per_page=100' \
"data": [
"name": "Developers",
"users_count": 10,
"updated_at": "2025-01-10T00:00:00Z"
"total": 1,
"page": {
"number": 1,
"size": 100
}Get user group by ID
Retrieve details of a specific user group by ID.
GET /api/iam/user_groups/:user-group-idURL parameters
| user-group-id | string required | User group ID. |
Sample request
curl -X GET 'https://www.workato.com/api/iam/user_groups/:user-group-id' \
"data": {
"users_count": 10,
}Create user group
Create a new user group in your workspace.
POST /api/iam/user_groupsPayload
| user_group.name | string required | Name of the user group. |
Sample request
curl -X POST https://www.workato.com/api/iam/user_groups \
-d '{
"user_group": {
"name": "Sales Group"
}'Response
"data": {
"name": "Sales Group",
"users_count": 0,
"created_at": "2025-01-20T00:00:00Z",
"updated_at": "2025-01-20T00:00:00Z"
}Update user group
Update an existing user group name.
PUT /api/iam/user_groups/:user-group-idURL parameters
Payload
| user_group.name | string required | Updated name for the user group. |
Sample request
curl -X PUT https://www.workato.com/api/iam/user_groups/:user-group-id \
-d '{
"user_group": {
"name": "Sales training group"
}'Response
"data": {
"name": "Sales training group",
"users_count": 10,
}Delete user group
Delete a user group from your workspace.
GROUP DELETION DOESN'T DELETE USERS
This action permanently removes the user group. Users assigned to the group aren't deleted, but are removed from this group.
DELETE /api/iam/user_groups/:user-group-idURL parameters
Sample request
curl -X DELETE 'https://www.workato.com/api/iam/user_groups/:user-group-id' \
"data": null
}Add users to group
Add multiple users to a user group in a single operation.
POST /api/iam/user_groups/:user-group-id/add_usersURL parameters
Payload
| user_ids[] | array[string] required | Array of user IDs to add to the group. |
Sample request
curl -X POST https://www.workato.com/api/iam/user_groups/:user-group-id/add_users \
-d '{
"user_ids": ["user-id-1", "user-id-2"]
}'Response
"data": null
}Remove users from group
Remove multiple users from a user group in a single operation.
DELETE /api/iam/user_groups/:user-group-id/remove_usersURL parameters
Payload
| user_ids[] | array[string] required | Array of user IDs to remove from the group. |
Sample request
curl -X DELETE https://www.workato.com/api/iam/user_groups/:user-group-id/remove_users \
-d '{
}'Response
"data": null
}List group members
List all members of a specific user group.
GET /api/iam/user_groups/:user-group-id/membersURL parameters
Query parameters
Sample request
curl -X GET 'https://www.workato.com/api/iam/user_groups/:user-group-id/members?page=1&per_page=100' \
"data": [
"id": "user-id",
"status": "active",
"user_groups": [
"total": 1,
"page": {
"number": 1,
"size": 100
}App links
An app link maps a user's Workato Identity account to their corresponding account in a specific app, such as Slack, Microsoft Teams, or Workato GO. For example, it connects [email protected] in Workato Identity to @jade in Slack. You can create app links in Workato Identity without requiring users to sign in first. This allows you to send app events, notifications, or automations to your entire organization through a connected app immediately.
The following endpoints enable you to manage Workato Identity app links:
List app links
List all app links in the current environment.
GET /api/iam/app_linksQuery parameters
| app_type | string optional | App type: slack, teams, or matrix. |
| app_user_id | string optional | App user ID. |
| app_user_ids[] | array[string] optional | App user IDs. |
| user_id | string optional | Workato user ID. |
| user_ids[] | array[string] optional | Workato user IDs. |
| state | string optional | State: initial or linked. |
| order_by | string optional | Sort by app_type, state, linked_at, or created_at. |
| per_page | integer optional | Page size. Set to the default maximum of 100. |
Sample request
curl -X GET 'https://www.workato.com/api/iam/app_links?page=1&per_page=100' \
"data": [
"id": "7H9UjixTng97i7dTSXMYpo",
"app_type": "slack",
"app_user_id": "/slack/teams/T083UTJ97C1/users/U083G78PZV0",
"user_id": "user-id",
"state": "linked",
"linked_at": "2025-01-15T10:30:00Z",
"updated_at": "2025-01-10T00:00:00Z",
"auth_link": null
"id": "4YYoEcATHdUVHceXUHymKY",
"app_type": "teams",
"app_user_id": "/teams/teams/1a30ead4-ab61-473e-8c8a-a83eb2948145/users/cb3bbf8f-579e-41c6-89ad-5927346f8944",
"state": "linked",
"auth_link": null
"id": "yDQe8Ua4PKQWT7hDMAPgi",
"app_type": "matrix",
"app_user_id": "[email protected]",
"state": "linked",
"auth_link": null
"total": 3,
"page": {
"number": 1,
"size": 100
}Create app link
Create a new app link in your workspace.
POST /api/iam/app_linksPayload
| app_type | string required | App type: slack, teams, or matrix. |
| app_user_id | string required | User ID in the app. Format varies by app type: • Slack: /slack/teams/{team_id}/users/{user_id}• Teams: /teams/teams/{team_uuid}/users/{user_uuid}• Matrix (GO): User email address |
| user_id | string optional | Workato user ID. The link is created in initial state if omitted. |
Sample request
curl -X POST https://www.workato.com/api/iam/app_links \
-d '{
}'Response
"data": {
"id": "app-link-id",
"state": "linked",
"auth_link": "http://id.workato.com/portal/workspaces/<ID>/environments/<ENV ID>/sign-in?app_link_unique_id=<APP LINK ID>"
}Delete app link
Delete an app link from your workspace.
DELETE /api/iam/app_links/:idURL parameters
| id | string required | App link ID. |
Sample request
curl -X DELETE 'https://www.workato.com/api/iam/app_links/:id' \
"data": null
}Delete app links
Delete multiple app links from your workspace in a single operation.
DELETE /api/iam/app_linksPayload
| ids[] | array[string] optional | App link IDs to delete. |
Sample request
curl -X DELETE 'https://www.workato.com/api/iam/app_links' \
-d '{
"ids": ["app-link-id-1", "app-link-id-2"]
}'Response
"data": null
}Last updated:
