# Community library
COMMUNITY ASSETS ARE INTENDED AS EXAMPLES ONLY
Platform Assets created and marked public in the community library are intended to serve as a reusable set of templates, best practices and guidelines for different types of solutions. You can learn from, modify, customize and enhance it to meet your specific requirements and business needs. It enables you to expedite the implementation and rollout of integration and orchestration solutions and projects across the organization.
The community library allows you to find and install platform assets, such as community recipes, community connectors, and skill recipes created by other builders. These pre-built solutions can be customized to fit your needs, helping you quickly integrate and orchestrate automations without starting from scratch.
You must agree to Workato's community policy (opens new window) to use the community library.
# Browse assets
The community library has integrated filters and search to help you find assets that are relevant to your use case. Popular use cases include AI/Machine Learning, Finance and Accounting, Operations, and more.
You can filter assets by use case or by the applications they use.
You can toggle filters in the community library's sidebar or enter them in the search bar.
To add filters to the search bar:
- Enter
app:
orcategory:
followed by the app or category name. - Put quotation marks around the app or category name if it contains a space.
- Separate each new filter with a space.
The following example shows how to use filters in the search bar:
app:Workday app:"Google drive" category:Utility
# Permissions
You must have specific privileges to perform the following actions in the community library:
Installing connectors
Full access to the Connector SDK is required to install connectors from the community library.
Cloning recipes
Recipe creation permissions are required to make copies of recipes from the community library.
Uploading connectors
Full access to the Connector SDK is required to upload connectors to the community library.
Uploading recipes
Recipe editing permissions are required to upload recipes to the community library.
