Community library
The community library allows you to find and install platform assets, such as community recipes, community connectors, and skills created by other builders. These pre-built solutions can be customized to fit your needs, helping you quickly integrate and orchestrate automations without starting from scratch.
You must agree to Workato's community policy to use the community library.
FEATURE AVAILABILITY
The Community library isn't accessible to workspaces in the China data center.
Customers using the China data center must build custom solutions or work with the Professional Services team to develop recipe templates, custom connectors, and best practices. Recipe lifecycle management (RLCM) features are supported for the China data center. This means that users can deploy assets to higher environments and import or export .zip files to their workspaces. This reflects local regulatory requirements and applies to our multi-tenant and Virtual Private Workato (VPW) offerings.
COMMUNITY ASSETS ARE INTENDED AS EXAMPLES ONLY
Platform Assets created and marked public in the community library are intended to serve as a reusable set of templates, best practices and guidelines for different types of solutions. You can learn from, modify, customize and enhance it to meet your specific requirements and business needs. It enables you to expedite the implementation and rollout of integration and orchestration solutions and projects across the organization.
Browse assets
The community library has integrated filters and search to help you find assets that are relevant to your use case. Popular use cases include AI/Machine Learning, Finance and Accounting, Operations, and more.
You can filter assets by use case or by the applications they use.
You can toggle filters in the community library's sidebar or enter them in the search bar.
To add filters to the search bar:
- Enter
app:orcategory:followed by the app or category name. - Put quotation marks around the app or category name if it contains a space.
- Separate each new filter with a space.
The following example shows how to use filters in the search bar:
app:Workday app:"Google drive" category:UtilityPermissions
You must have specific privileges to perform the following actions in the community library:
Installing connectors
Full access to the Connector SDK is required to install connectors from the community library.
Cloning recipes
Recipe creation permissions are required to make copies of recipes from the community library.
Uploading connectors
Full access to the Connector SDK is required to upload connectors to the community library.
Uploading recipes
Recipe editing permissions are required to upload recipes to the community library.
Community recipes
Community connectors
Skills
Filter assets by use case
Filter assets by application
