# CSV tools by Workato
The CSV tools by Workato connector provides actions to process CSV (comma-separated values) files directly within recipes. You can use this connector to ingest, transform, and export tabular data without relying on external services.
Most web applications return CSV files without additional processing. You can use the CSV tools by Workato connector to:
# Setup
CSV tools by Workato is a built-in connector. It doesn't require authentication or connection setup.
