SAP - New IDocs batch trigger
The New IDoc batch trigger allows you to listen to outbound IDocs from SAP in real time. You can use this trigger to process multiple IDocs in a single job. Note that the New IDoc batch trigger is only compatible with OPA v23.0 and higher.
You can configure the SAP system partner profile to enable sending multiple IDocs in one transaction to fully leverage this feature. This allows you to process IDocs in batches and improve your IDocs transfer speed from system to system. IDoc batches are sent to Workato's webhooks gateway and have the following limits:
| Description | Limit |
| Maximum webhook payload size (bytes) the New IDocs (batch) trigger | 10 MB |
| Maximum webhook rate limits for the New IDocs (batch) trigger |
| Maximum byte limits for the New IDocs (batch) trigger |
Refer to the webhooks rate and memory limits section for more information.
LARGE BATCH SIZES
Configuring batch sizes larger than 1000 in SAP can result in errors.
BEFORE YOU BEGIN
You must configure IDocs in your SAP system before using this trigger.
How batching works with IDocs
The New IDocs batch trigger process events based on the batch size you configure. For example:
Example 1
If you configure your batch size to 5 but ten IDocs are sent, two jobs are created with each job containing five IDocs.
Example 2
If you configure your batch size to 5 but two IDocs are sent, one job containing two IDocs is created.
Input
| IDoc type | Select an IDoc type from the drop-down menu or enter an IDoc type manually using the format message_type.basic_type.extension. For example: ORDERS.ORDERS05 or DEBMAS.DEBMAS03.ZDEBMAS. If the IDoc type you plan to use is not available in the drop-down menu, consider configuring the IDoc in the WE20 dialogue in the SAP system before establishing a connection between Workato and SAP. |
| Batch size | Set a batch size between 1 to 1000 to process multiple IDocs per job. The batch size should align with the solution architecture and Workato webhook volume limits. Consider using the 'New IDoc' trigger (without the batch tag) for single-document processing. |
Configure batch size
MESSAGE TYPE, BASIC TYPE AND CUSTOM EXTENSIONS
We subscribe to one message type, basic type, and custom extension (if applicable) at a time. You must maintain the recipe logic to ensure that the workflow processes appropriately for different partners. For example, you can apply the condition on the RCVPRN datapill from the trigger or add the RCVPRT datapill in addition to the RCVPRN datapill.
Output
The output for this trigger includes all segments and data fields for the IDocs received from the SAP system.
