Pre-built Connectors
Pre-built connectors let you integrate Workato with popular apps and services. Each connector includes ready-to-use triggers and actions, and is maintained by Workato.
The Pre-built connectors section contains the following information:
- How to connect the app with Workato
- Roles and permissions required to establish a connection
- Using the triggers
- Using the actions
- Troubleshooting common errors
FEATURE AVAILABILITY
OAuth 2.0 connectivity requires additional configuration for workspaces using the China data center.
Customers using the China data center must configure Custom OAuth profiles before establishing connections to connectors that support OAuth 2.0 authentication. Custom OAuth profiles can require the following customer-provided credentials:
- Client IDs
- Client secrets
- OAuth 2.0 endpoint URLs
Additionally, certain connectors aren't available to workspaces in the CN data center. This reflects local regulatory requirements and applies to our multi-tenant and Virtual Private Workato (VPW) offerings.
Refer to the CN data center page for more information.
Connector directory
The following directory lists all officially supported platform connectors. You can select a letter in the sidebar on the right to jump to connectors starting with that letter.
If a connector is missing from this list, reach out to Workato support.
You can also visit our app integrations directory to search by category.
COMMUNITY CONNECTORS
Community connectors are custom connectors built and shared by Workato users. For a list of all community connectors, see the community library.
A
B
C
D
E
F
G
H
I
J
K
L
M
N
O
P
Q
R
S
T
U
V
W
X
Y
Z
