# Set up extraction frequency
Define how often Workato extracts data from your source systems. Workato supports the following methods for data processing:
Extracts and processes data in groups of multiple records or rows. You can use batch processing to move large volumes of data efficiently during scheduled transfers.
Extracts larger datasets than batch processing, maximizing throughput and efficiency. You can use bulk processing for full data loads or large-scale migrations.
Extracts and processes data immediately as it becomes available. You can use real-time extraction when you need instant data access, such as for monitoring, alerting, or live dashboards.
Checks for new data at regular intervals and processes small sets of records. You can use micro-batch or polling to balance timely data updates with reduced system load.
Last updated: 2/19/2025, 10:15:52 PM
