# ELT Pipeline for Snowflake accelerator - Assets
# Installation files
This accelerator's assets include the following files, and their components:
- ELT_Pipeline_for_MS_Teams.zip is the core asset package you must import if you plan to implement the ELT Pipeline bot in Microsoft Teams.
- ELT_Pipeline_for_Slack.zip is the core asset package you must import if you plan to implement the ELT Pipeline bot in Slack.
# ELT_Pipeline_for_MS_Teams.zip
You must import this core asset package to implement the ELT Pipeline bot in Microsoft Teams.
This package contains the following components:
13 Recipes
- 3 active
- 10 callable
7 Lookup tables
- ELT | User Access
- ELT | Systems
- ELT | Objects
- ELT | JOB TABLE
- ELT | ERROR LOGS
- ELT | CONTROL TABLE | MAIN
- ELT | CONTROL TABLE | CHILD
10 Properties
- elt.user_section_text
- elt.user_button1_url
- elt.user_button1_label
- elt.snowflake_url
- elt.msteams_notification_channel
- elt.s3bucketregion
- elt.s3bucketname
- elt.bot_app_id
- elt.aws_secret_key
- elt.aws_key_id
- elt.admin_guide
9 Connections
- ELT | CON | Snowflake through JDBC
- ELT | CON | SQL Server through JDBC
- ELT | CON | SF Partner Account
- ELT | CON | S3
- ELT | CON | PostgreSQL through JDBC
- ELT | CON | On-prem-File
- ELT | CON | ELT Workbot for Microsoft Teams
# ELT_Pipeline_for_Slack.zip
You must import this core asset package to implement the ELT Pipeline bot in Slack.
13 Recipes
- 3 active
- 10 callable
7 Lookup tables
- ELT | User Access
- ELT | Systems
- ELT | Objects
- ELT | JOB TABLE
- ELT | ERROR LOGS
10 Properties
- elt.snowflake_url
- elt.slack_notification_channel
- elt.s3bucketname
- elt.bot_app_id
- elt.aws_key_id
- elt.admin_guide
9 Connections
- ELT | CON | S3
- ELT | CON | ELT Workbot for Slack
