# ELT Pipeline for App homepage
The ELT Pipeline for Snowflake App homepage contains three main sections:
The Quick links section lets you pin links to the top of the App homepage. For example, you can pin the link to the Admin guide (a pdf version of the ELT pipeline accelerator documentation) and other helpful links. You can customize these links using properties listed in our ELT pipeline properties documentation.
Admin/installation guide
Change the URL in the elt.admin_guide property.
ELT | Access | Snowflake
Change the URL in the elt.snowflake_guide property.
ELT | User section text
Change the button's label text and URL by modifying the elt.user_button1_label and elt.user_section_text properties. To customize the section text, edit the elt.user_section_text property.
# ELT pipeline options
The ELT pipeline options interface enables you to create a pipeline, search for a pipeline, add a source object, and add/update users.
USER PERMISSIONS
Only users with an Admin role have permission to add a source object or modify users.
# List of ELT pipelines
The List of ELT pipelines section contains the following lists of pipelines:
Most recent active pipelines
Active pipelines that the ELT Pipeline bot recently processed.
Most recent pending pipelines.
Recent pipelines that are awaiting processing.
Most recent inactive pipelines.
Pipelines that have errored out or were manually deactivated.
