# Auth token
# Header
An Auth token is the simplest way to authenticate an API request with Workato.
How can I retrieve a new Auth token?
You can retrieve an Auth token when you create a new access profile. You can only view this token once. If you lose the token, you will need to refresh and retrieve a new token.
Go to Platform > API Platform > Clients.
Click on the access profile you plan to retrieve an Auth token for.
Click the Refresh button next to the Auth token to generate a new one. Note that refreshing your Auth token will revoke access for clients using the current Auth token.
Refresh the Auth token
Save your Auth token in a secure place.
Configure a header with your Auth token. For example:
-H 'api-token: ed776fdfbf5003b4aa6bcaafea8f9003ffb6986454822ce7ebb3c1a8efc08348'
Now, when an API request is made, Workato will read this header value and recognize that the request is from a verified access profile.
# Basic authentication
You can authenticate the API request using the basic auth scheme (opens new window). Use api-token as the username and your token value as the password. For example, in curl, you can pass the following credentials with the -u option:
-u api-token:ed776fdfbf5003b4aa6bcaafea8f9003ffb6986454822ce7ebb3c1a8efc08348
This command automatically constructs the Authorization header in the following format:
-H 'Authorization: Basic <encoded api-token:token>'
