# ADP Workforce Now
ADP Workforce Now is an HCM solution for midsized companies. It includes solutions for HR management, payroll, benefits, talent management, compliance, time, and labor management and analytics and benchmarking.
# API version
The ADP Workforce Now connector uses the ADP Workforce Now API v2 (opens new window).
# How to connect to ADP Workforce Now on Workato
Configured ADP Workforce Now connection
Field Description
Connection name Give this ADP Workforce Now connection a unique name that identifies which ADP Workforce Now instance it is connected to.
Client ID API client ID used to interact with the API.
Client secret API client secret used to interact with the API.
SSL client certificate SSL client certificate. Copy and paste the contents of the cert file (for example, com.workato.prod.pem).
SSL client key SSL client key. Copy and paste the contents of the key file (for example, workato_ADP.key).
Custom CA certificate Key passphrase for SSL. It should be the same string used to generate the SSL key.
