Azure File Storage - Create directory action
The Create directory action creates a new directory in Azure File Storage under a specified share or parent directory. The parent directory must already exist, and you can't create a directory hierarchy in a single action.
Input
| Directory path | Enter the path to the directory you plan to create. For example, hrdata/reports/2025. The parent directory must already exist. |
| Creation time | Enter the UTC creation time for the directory. Leave empty to use the current time. |
Output
| Status code | HTTP status code of the operation. |
| Response headers | HTTP response headers including ETag, last modified, file creation time, last write time, permission key, attributes, file ID, parent ID, and request ID. |
