Azure File Storage - Rename directory action
The Rename directory action renames an existing directory within the same file share in Azure File Storage. The source directory must exist, and the destination directory must not already exist unless you enable Replace if exists.
Input
| Source path | Enter the path of the existing directory to rename. For example, hrdata/old_reports. |
| Destination path | Enter the new path for the directory. For example, hrdata/new_reports. The destination must not already exist unless Replace if exists is enabled. |
| Replace if exists | Enable to overwrite the existing destination. |
| Ignore read-only | Enable to rename only if the destination has the read-only attribute. Requires Replace if exists to also be true. |
| Metadata | Specify key-value metadata pairs to set on the renamed directory. Each call replaces all existing metadata. Keys must follow C# identifier naming rules. |
| Headers | Specify HTTP request headers to customize file permissions, attributes, timestamps, lease validation, client request tracking, and trailing dot behavior. |
Output
| Status code | HTTP status code of the operation. |
| Response headers | HTTP response headers including ETag, last modified, file creation time, last write time, permission key, attributes, file ID, parent ID, and request ID. |
