Ceridian Dayforce - New/updated employee trigger
The New/updated employee trigger activates when an employee is created or updated in Ceridian Dayforce.
Input
| Trigger poll interval | Select how frequently to check for new events. Defaults to minutes if left blank. Minimum value allowed is minutes. Refer to Polling intervals for more information. |
| When first started, this recipe should pick up events from | Set the date and time to start picking up trigger events. This enables your recipe to capture past events. Refer to Triggers to learn more about this input field. |
Output
| XRefCode | The external reference codes for the new/updated employees returned in your search. |
