# Conga Composer - Compose document action
The Compose document action generates a document by merging one or more templates with data collected from multiple sources in Conga Composer.
| JSON data | Enter the JSON data to include in the document. |
| Destinations | Enter information about the sources you plan to use to compose a document. |
| Template sources | Enter information about sources for the template you plan to use. |
| Salesforce request | Enter a Session ID for a salesforce request you plan to use to compose a document. |
| Activity | Enter the Attach operation you plan to use to compose a document. |
| Status code | A code indicating the status of the document. |
| Is successful | A message indicating if the action was successful. |
| Pre signed create response model | Information about the response model, including Correlation ID and File info details list. |
Last updated: 4/29/2026, 7:02:48 PM
